Old 01-29-2018, 07:23 AM
kava kava is offline
Default no sidechains in offline bounce
maybe it's a double post, but I cannot find any serious info on this.
when I do sidechain/ducking compression (Waves RenComp used as multiple mono), most of the time ducking my stems a little with signal from the voicover (5.1 post), I cannot use offline bounce. I always use multimono comps for ducking because I want different att/rel times for the Center and the other channels in dense mixes.
When I print my master bus the ducking works, offline bounce of the same bus won't work, so it's definitely no routing issue.
anybody else experiencing this?
Mac Pro 2019 16-Core, 144GB Ram, OS X 10.15
ProTools Ultimate, 2x HDX
NTP Penta720 I/O + 192 HD I/O + SSL Madi Link
Sync HD, Dolby Atmos RMU
S6 - M40 - 32channel.
Filmpost at cosmix studios vienna
http://www.cosmix.at
http://www.tom-kava.com
Old 01-29-2018, 10:39 AM
john1192 john1192 is offline
Default Re: no sidechains in offline bounce
just did a sidechain offline bounce test here with NON-HD and it works as it should !!!
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 06-29-2018, 06:12 PM
milosziv milosziv is offline
I've been having this problem as well! BUMP!
Old 05-22-2019, 06:41 AM
Goath Goath is offline
I know it's an old thread but as there was no solution I decided to post it. I had this problem these days. After spending hours trying to figure out I was able to resolve by routing my aux for physical outputs instead of buses. mix 5.1 for outputs 1 - 6 and mixdown 2.0 for outputs 7 - 8. On the bounce dialogue box I set the source Physical Output.
Old 10-06-2022, 10:02 AM
BUMP!
This bus is still there (for HDX Systems only)
I cannot do offline bounces on my HDX System (mow M1, 2022.9) with sidechained MultiMono Plugins. Goath Solution doesn't work for me.
on my native System the offline bounces work well....
Avid...please solve that....
PT 12.5.2 Offline Bounce - Different Levels after Bounce ?? innenhofstudios Pro Tools 12 3 01-29-2018 08:56 AM
Offline bounce crash, probably Waves-related, and offline bounce not 100% correct Skwaidu Pro Tools HDX & HD Native Systems (Mac) 3 03-23-2015 03:55 PM
Offline bounce vs. Realtime bounce significant differences Mano Pro Tools 11 13 05-29-2014 05:58 PM
offline bounce different than realtime bounce grant howarth Pro Tools 11 8 12-08-2013 09:29 PM
Offline bounce spyfly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-21-2007 12:50 PM
