Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Mac)
Old 01-13-2013, 11:10 AM
kahico kahico is offline
Default EQ in PRotools SE
Im new to protools and just purchased the M-Audio MoblePre with Protools SE to do voiceovers. Ive set it up to my MacBook Pro and began to record. Ive noticed a dull maybe dead sound. How do I fix this problem. The controls I have in the protools SE are,
LOW SHELF, LM FREQ, LM GAIN, HM FREQ, HM GAIN, HIGH SHELF
Can anyone explain what they mean. I've tried looking it up but am having trouble.
Mahalo for the help!
Old 01-13-2013, 11:37 AM
These frequecy bands run at progressively higher frequencies, low, low-mid, high-mid, high. They are all band pass except the low and high that act as shelf filters. You can google "shelf filter" , if that term is not obvious. The band adjustment will affect the frequency that EQ filter stage is tuned to, the gain knob adjusts how much gain or attenuation is applied to signals in that band.
There are lots of online resouces, multiple videos on you tube about using EQ that you can search for. I would hope the visual plugin display and just listening to things as you play with them explains what is going on. Grab some favorite commercial music with a wide range of say drums and vocals and paste it into a track in an empty session, stick an EQ plugin on that and just play with it.
if you are stuck on this type of stuff, my suspicion is that you are you provably would be better off sitting back with a tutorial, introductory guide or course. Two suggestions there are to look at the online Pro Tools specific courseware from Lynda.com or the general material from Allen Parsons http://www.artandscienceofsound.com/.
Darryl
changing from protools 8 audio only to protools 8 with video support djkaz macOS 5 09-04-2013 04:00 PM
ProTools Shortcut keys suddenly became disabled in ProTools LE 8.0.5? jgbsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-03-2011 01:08 AM
Protools 8 LE/ Error 5000 / Protools freezes constantly HELP! G ray 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-12-2011 07:09 PM
Sending protools projects to other protools users online kdtufan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-24-2008 07:18 PM
setting record levels into ProTools with the intent of mixing in ProTools Felix Tips & Tricks 507 02-05-2002 10:17 PM
