Help!!! Grid Mode Not Working.
I am having a panic attack over here....
The Grid in Grid Mode is gone... I can see it... each click. Gone! Not sure how this happened. I was working on a project, I saved it then closed it ate dinner blah blah blah..... back to work. Open the project and it's gone. Looked at my settings over and over with no luck. I was working with Midi Notes in the timeline. Now I have no Grid. I am running WinXP Sp2 PT 7.1 with Digi002. I tried opening other projects I have and they all are missing the grid lines in any mode. Please Help!!! |
Re: Help!!! Grid Mode Not Working.
Fixed using the below answer. (guess I should have read that post first) sorry.
- Delete DAE and Pro Tools preference files Start Menu > My Computer > Local Disk(C:) or correct hard drive (click "show the contents of this drive" if the files aren't displayed) > Program Files > Common Files > Digidesign > DAE > Right-click on the DAE Prefs folder and delete. Start Menu > My Computer > Local Disk(C:) > Documents and Settings > "Your user folder" > Application Data > Right-click on the Digidesign folder and delete. (If the Application Data folder is not showing: Tools Menu > Folder Options > View Tab > Select "Show Hidden Files and Folders" > Click Apply and OK.) - Delete the Digidesign Databases folders for all hard drives Start Menu > My Computer > Local Disk (C:) > Digidesign Databases > Right-click on the Digidesign Databases folder and delete. Repeat for all hard drives. Start menu > My Computer > Local Disk (C:) > Program Files > Digidesign > Pro Tools > Databases > Right-click on the Volumes folder and delete. |
It was most likely a preference file.
This has happened to me once before. There must be a short cut key combo I was unaware of. There is a Display Preference option in the Preferences Box titled "Draw Grids in Edit Window" That was probably it or maybe not. Glad everything worked out for you. |
filosofem
Aaron Mulqueen - 001 HD Native |
Grid view in grid mode vs in shuffle mode | ryancousins | Getting Started | 4 | 04-13-2013 10:41 AM |
Grid mode, shuffle mode, spot mode and slip mode. | RogTaylor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-24-2010 10:30 AM |
BUG?: Selecting Frames in Grid Mode Not Working | i hear dead people | Pro Tools TDM Systems (Mac) | 4 | 02-27-2007 05:15 PM |
GRID mode/button not working anymore? | polaredit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-09-2006 05:42 PM |
Grid Lines - Slip Mode vs. Grid Mode | Mt.Everest | Pro Tools TDM Systems (Mac) | 24 | 02-20-2006 08:38 AM |
