Old 09-20-2003, 02:00 AM
frenchman frenchman is offline
Default Renaissance channel vs Channel Strip
First mix in PT6 and no Sony yet in my OSX config, so I decided to use the Renaissance plugs instead and notably the "Renaissance Channel" I got when upgrading Waves V4
Frankly I have been blown away by the sound of it : better to my ears than MHL Channel Strip.
For those of you who haven't seen it, it is a sort of combo between Ren EQ (only four band unfortunately) and Ren Comp/ RenVox. Also you can use both expander and compressor at the same time (can't do that on RenComp).
Frankly I like the concept because it means less going in and out of the TDM bus, less time slots, and the expander for once is excellent. Very silky sounding.
I would love to hear other opinions on this, notably from advocates of Channel Strip.
Mark Haliday
Mark Haliday
France, Rochefort 17300
Mixing & Mastering, Writer, Teacher
Pro Tools Ultimate & Carbon
M2 Max Studio
Old 09-20-2003, 05:18 AM
sdevino sdevino is offline
Default Re: Renaissance channel vs Channel Strip
I too found my channel strip sitting idle quite a bit once I got the Waves Ren comp and EQ. Most of the time I like the sound of the RenComp better. But I thought the channel strip EQ was a little more dynamic. However the fact that I got the GM EQ and MH has been slow to upgrade CS for OSX has given me time to learn to love the other options. GM EQ is my first choice over Sony Oxford Ren EQ and CS. I use the others just for a little sonic variation when needed.
Steve
Steve Devino
Granite Rocks Live
Authorized Metric Halo Dealer
1-603-867-6843
Renaissance Compressor wont Load in Multi Channel mode Ke productions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-21-2010 07:39 AM
Analog Channel(AC1) or Renaissance Channel Choral14 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-29-2006 07:07 AM
Waves Renaissance Channel Palli-Moon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-24-2006 12:11 PM
At last!!! Channel Strip for OSX chrispnyc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-28-2004 02:21 PM
Waves Renaissance Channel marcusb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-15-2003 12:35 AM
