Old 02-06-2001, 08:32 AM
knewbee knewbee is offline
Default Change Velocity
Not that this matters with 5.1 about to come out (hopefully anyway), but is it just me, or does the Change Velocity command to set the Min / Max range not work at all in 5.0.1??? The user interface for that menu makes no sense at all, and every time I try to do Min/ Max range, it sets everything to the same value...
Old 02-06-2001, 02:12 PM
lwilliam lwilliam is offline
Default Re: Change Velocity
I've used it several times. It seems to work for me, but the interface, with all of its different options, IS a bit confusing. Make sure you don't have extra things "x"ed out or enabled.
For instance, I've set max to 112 and min to 35 and it's worked just fine, bringing UP the lowest ones and bringing DOWN the higher ones.
LW
Larry
PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins.
Old 02-06-2001, 02:20 PM
IWilliam, thanks for the reply. I should check it out again, but when last I looked all the other options were Radio Buttons, so you HAD to pick one option, none of which are relevant to the Limit command. But I shall look more closely...
Change velocity on selected events stigc56 macOS 2 11-09-2013 03:23 AM
Change Velocity Glitch? lozkane Tips & Tricks 2 02-08-2010 11:57 PM
Easy way to change oto velocity view?? mmf78 Tips & Tricks 4 03-02-2007 04:22 PM
Change Velocity input level in PT stringster MIDI 2 08-01-2006 12:57 PM
PT crashes when closing the 'change velocity' window. mlemos 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-17-2003 05:30 AM
