Old 02-06-2001, 12:20 AM
Azael Azael is offline
Default double,twice,again
O.k. I have another qestion, since am force to use the G bank sounds for right now. I use the drum that are there and experiment with those drums in midi but some times I hear the notes echo,double, repeat etc. why is that am I hiting the notes to fast or do I have something on or off that is making this happen. The digi support team said it was my triton but I just got it. So far it's been what the drums only because thats the only thing I tried to experiment with but I'll try some other instruments and let ya know if it does this also.
Please Help
Thank YOU
Old 02-06-2001, 03:07 AM
Neil Ward Neil Ward is offline
Default Re: double,twice,again
Howzit!
Double notes are usually in indication that your keyboards 'local switch' is still on. If you are using this keyboard to input notes to PT then you must switch 'local' OFF.
//NW
[This message has been edited by Neil Ward (edited February 06, 2001).]
Old 02-08-2001, 07:36 PM
I already have local control on off but it still does that anymore suggestions? my triton manual reads something about echo could that be the problem?
Old 02-08-2001, 07:38 PM
Old 02-10-2001, 08:30 AM
accession accession is offline
Hi Azael,
Let's see....
- With 'local' switched off in your Triton, can you still hear it play whe you hit the keys (when not set up to receive MIDI in PT)? In theory, it should be silent. If not, check it again, or go to the MIDI menu and uncheck the MIDI Thru option.
- Are you using the sequencer from the Triton to play the notes? (Does this thing even have a sequencer?) If so, the 'local' command may only bypass the physical keys, in which case, go to the MIDI menu and uncheck the MIDI Thru option.
- Are you using a third-party MIDI Interface? Let's hope so, because this is my last possible soloution. A problem I couldn't pick for a while was where PT would receive *and* record two notes for every one. Try doing this with monophonic sounds and it would cause havoc. Go into the MIDI menu's Input Devices and be sure that only your Triton (and whatever other synth's you have) are checked. Your MIDI Interface should be UNCHECKED. Otherwise PT registers notes coming from both the synth (via the interface), and from the interface (originally from the synth).
Please post back and let me know if this gets you out of trouble.
Cheers,
Phil
Old 02-10-2001, 08:33 AM
Hi again,
...er, why are you 'forced to use the G Bank sounds for now'?
Phil
PT7 Double cursor tmmsrv Pro Tools TDM Systems (Win) 5 12-08-2007 02:10 PM
S-MUX / Double Speed / Double wire jiggy_bau Pro Tools TDM Systems (Mac) 3 06-27-2005 09:36 AM
Double upgrade doylemusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-25-2005 04:13 PM
Double Whammy. Bluemoon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 06-09-2005 02:16 AM
i'm i seeing double? surgestrip 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-10-2001 08:36 PM
