Electric bass record.
Which the best way to record electric bass with DIGI001? [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img]
Rafael Tavares |
Re: Electric bass record.
Best? I Don't know. I go into a Pod Pro, and from there I use s/pdif to get into PTLE. Cheers, Mark <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by sower: Which the best way to record electric bass with DIGI001? [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img]<HR></BLOCKQUOTE> |
you could use the pod or something similar but my favourite bass method is to get a good sound from the guitar and amp and mic it with a large diaphragm condenser (usually a U89) then just a touch of compression (my favoured units being an LA2A or Distressor) and it always comes up rockin'. i've had ok results from other mics so just use your ears and go with whatever sounds best to you [img]images/icons/smile.gif[/img] i don't think i've ever used the di track in a mix...
~matt |
I was using POD but now I use the Tech21 bassdriver. It makes it sound really big in the mix. It's a DI with some amp emulation (sort of), but it really sounds good at half the price of a POD. Check it out at http://www.tech21nyc.com/. You go straight into one of the inputs.
ASUS A7N8X-E Deluxe MD Athlon XP3200+2.20GHZ Corsair XMS PC3200 400MHZ 1GB WD EIDE 10GB WD EIDE 250GB XP Pro SP1 ProTools LE 6.4 |
i have used a really cheap di-box to record a bass-guitar to tape, so i think it would do the trick to with the digi001. Just plug it in directly. Then later on you can add some eq to get the sound right.
Bastiaan
What's that? - That's the machine that goes "pling". Bastiaan |
Tube DI and a compressor. Though it all starts with a good bass with new strings and a capable player... [img]images/icons/wink.gif[/img]
sower,
I have also had great results using my SansAmp Bass DriverDI(Tech21). Marc |
Get the Pod. You can get a totaly pro sound with it, it's cheap, easy to use, and the support for it is great.
Looking for a good electric bass VI | Legion6789 | Pro Tools 9 | 27 | 09-14-2011 03:59 AM |
Best Electric Bass Samples? | aus scott | Tips & Tricks | 5 | 05-30-2009 01:39 AM |
Question on Eqing electric Bass guitar | rhythmg | Tips & Tricks | 3 | 07-17-2006 05:40 AM |
the best way to record electric guitar & bass | idolizetravis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-14-2005 07:54 PM |
Electric bass record. | sower | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 01-22-2002 03:49 PM |
