  #21
Old 11-04-2014, 09:50 PM
Brandonx1 Brandonx1 is offline
Default Re: Love em or Hate Waves finally puts DLS bundles on sale
Ok I get it now. So you would be limited to 32 io and can't use a sync hd. Got it.
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
  #22
Old 11-12-2014, 11:02 PM
Table Syrup Records's Avatar
Table Syrup Records Table Syrup Records is offline
Actually 64
"DLI/DLS can stream up to 64 channels, which you can use for processing or I/Os—or both."
You can also use your existing TDM plugs if you have em :)
I would think you could still use a Sync HD, with PT setup for it, and in the Waves pref's, set source to external ??
Worst case, in standalone? I would have to look into this one.
Even if you could, I'm not sure you'd want to or need to.... I'm betting on very solid clocks in the Waves hardware.
AAAAAND, all the clocking is remote controlled anyway, just like with Sync HD, so what's the advantage of it? I doubt there is one.
Here is a good read:
http://www.waves.com/1lib/pdf/hardwa...dli-manual.pdf
Shorty: Table Syrup Records
Mac Pro 5,1 3.33 GHz Hex, 32GB
EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23"
OSX Sierra
Pro Tools HD 11.2.2
Waves IOS, IOX, STG2412
Extreme Server (x2)
Logic Pro X, DSP Quattro, Final Cut Pro X
Waves Mercury+SSL+AbbeyRoads
Trident S65 with embedded US-2400
Live:
2012 Mac Mini, Dual SSD, i7 2.4, 16GB
Win 10, OSX Sierra
LV1, MRSG
Hardware from above (same gear)
Dual Dell P2418HT Touch Screens
Waves Icon X (x2), M, with Screens
Custom enclosure
  #23
Old 11-13-2014, 07:41 AM
Originally Posted by Table Syrup Records View Post
Actually 64
This can't be right. If you are not using hdn or hdx, pro tools is limited to 32 I/o. Sync hd is very important for post production. You need it for machine control, sync to video and a bunch of other functions.
We have 2 different scenarios here.
1. Use the waves server as a sound card. Limited as above
2. Use hd native or hdx as a the playback engine in pt and you have to go in and out of the hardware buffer plus waves hardware latency for any processing.
How does this waves server work with an avid control surface? Can you edit a plug in or even use pro tools automation with it?
Anyway, I don't really care much. I really don't like any waves plug ins. I find way better alternitives in other 3rd party plug ins.
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
  #24
Old 11-13-2014, 09:12 AM
64 I/O with HD, 32 with Vanilla. Vanilla is limited to 32 with ANY hardware
Also, I'm still THINKING with HDN/HDX you could control a SyncHD, and set Waves units to external clock - tadda - eveything still works via Sync HD as you wanted it to.... Again, I have yet to confirm this, but I am betting you can.
Even HDX users could benefit from it. A single DLS spanks the plugin instance capability of a single HDX at a fraction of the cost.
For HDN Users it is even a sick deal, PTHD features, Offload DSP, - far cheaper than the upgrade path to DSP and more powerful
Had Waves DLS been out, at the time I upgraded to HDN, I would most likely have gone Waves.... and next time I expand or upgrade, I will most likely be going there.....
Just my $.02
Not trying to argue with you, it seems you obviously don't like it.
So it's not for you. But for many of us, this is a great solution.
You know, all these things in 'question' could be answered with probably a 5 minute phone call to Waves lol
OSX Sierra
Pro Tools HD 11.2.2
Extreme Server (x2)
Live:
Win 10, OSX Sierra
LV1, MRSG
Custom enclosure
  #25
Old 11-13-2014, 09:20 AM
JFreak's Avatar
JFreak JFreak is online now
HD software supports unlimited i/o but the actual numbers depend on the hardware.
For example, HDN is 64 i/o max.
Janne
  #26
Old 11-13-2014, 10:10 AM
Correct, and PT Vanilla is still limited to 32. HD is 64.
http://www.avid.com/US/products/Pro-...Specifications
Supported tracks:
Pro Tools 11
96/48/24 maximum simultaneous audio tracks @ 48/96/192 kHz
Up to 32 Inputs and 32 maximum simultaneous audio record tracks
128 Instrument Tracks
512 MIDI tracks
128 auxiliary tracks
256 busses
1 video track
Pro Tools | HD 11
768/384/192* maximum simultaneous audio tracks @ 48/96/192 kHz
Up to 192 Inputs and a maximum of 256 simultaneous audio record tracks
256 Instrument Tracks
512 MIDI tracks
512 auxiliary tracks
256 busses
64 video tracks
OSX Sierra
Pro Tools HD 11.2.2
Extreme Server (x2)
Live:
Win 10, OSX Sierra
LV1, MRSG
Custom enclosure
  #27
Old 11-13-2014, 10:16 AM
propower propower is offline
Such a complicated product -
Sure - hook up and record low latency with WAVES (AVID i/o to DLS to Ethernet to Computer) - but now if you want to use someone else's plug in - BAM - 5 ms latency! (HDN was way less).
So you go through HDN - now the DLS has 2X the buffer setting + A/D D/A + 0.8ms - Native Waves in HDN is lower latency.
Now there are a ton of scenarios where DLS shines - but it can be very complicated. And like HDX - really works best if you only record with what runs on the DLS. Sadly the easiest integration is with HDX! But how many would do that.
2017 27" iMac 3.8GHz i5, 1TB SSD
Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB
Musician: http://www.ivanlee.net/
Design Engineer: http://www.propowerinc.com/resume.html
  #28
Old 11-14-2014, 07:46 AM
This is what I am trying to say. table syrup is conflating configurations. It's one or the other. You can use HDX hardware and get x2 the hardware buffer then using the waves thing OR you can use the waves thing as a sound card and get limited Io (32), just about the same latency unless you use any other plug in besides what runs on the waves server and no machine control or sync IO.
In reality, if you want to use PT and waves plug ins it's better to just use the waves native AAX plug in in pro tools and buy a fast, modern computer. Attaching the waves server won't get you better latency or more plug ins. It's just another thing to upgrade in a year and limits the hell out of your PT system in any configuration.
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
  #29
Old 11-14-2014, 07:50 AM
JFreak's Avatar
Waves have their own agenda now, they have completely 180-degreed on us. I won't be spending any money on their products anymore. Hopefully someone creates a C6 clone/killer and I will be a happy camper...
Janne
  #30
Old 11-14-2014, 08:03 AM
Drew Mazurek's Avatar
On the bright side, they are selling single plugins at reasonable prices (especially if you watch the sales) I've gotten C6 for $75, L3 for $84, etc.. and just use the native versions.
www.drewmazurek.com
FS: Waves Tony Maserati, Manny Marroquin bundles for sale! plunderpot Buy & Sell 1 07-07-2014 11:17 AM
x-form love/hate Kachunk Pro Tools 11 6 09-14-2013 07:13 PM
It's a Love Hate Thang ..... jayprotools Pro Tools TDM Systems (Mac) 1 12-29-2009 06:46 PM
Avalon 737: Love it or Hate it spicyitaliano General Discussion 8 02-10-2004 10:03 AM
I love and... hate Digi! smcoptyltd Tips & Tricks 0 01-27-2001 05:44 PM
