Old 07-16-2013, 12:37 PM
Snarf Snarf is offline
Default Export AAF in 11?
I can't seem to get the export/import AAF function workin in 11. Anybody else?
Stian Sylta
Producer/Songwriter/Musician
Sons Of Vanity on iTunes/Spotify
MacBook Pro i7/Apogee One/Duet/ElevenR/Pro Tools 12
Preamps from UA, Mackie and Avid.
Listening through Dynaudio, Genelec and ADAM
Old 07-16-2013, 05:35 PM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: Export AAF in 11?
Have you tried it this way?
Open a Workspace browser.
Drag a Pro Tools session file, or an AAF or OMF sequence, into the current session, as follows:
Drag onto an existing track to overlay or over- write data on the target tracks. Hold the Shift key while dragging if you intend to replace the cur- rent track playlists with those being imported (the Shift key pre-configures the settings in the Import Session Data dialog).
Drag to empty space in the Edit window to cre- ate new tracks for the imported session data.
Configure the Import Session Data options (see “Import Session Data Dialog” on page 328).
Also, see page 335 in the reference guide for more info.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
mp3 export doesn't show correct file size til another export done obidon Pro Tools TDM Systems (Mac) 0 12-09-2010 01:13 PM
Export MIDI produces corrupted data. Unable to export MIDI ! Chris7514 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-01-2007 07:18 PM
Can't export an OMF from PT jslater Pro Tools TDM Systems (Mac) 4 09-18-2003 09:42 AM
Where is my MP3 Export S/N? dans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-01-2003 12:07 AM
Export OMF johnkimble 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-22-2003 02:15 AM
