#21
Re: HD6 vs HDX2 "ITB" Listening Challenge
Hey Guys,
I just want to thank Tom and Avid for doing this with me. As someone who has made the switch to ITB mixing, this is the kind of test I was very interested to do. And thanks to everyone on this thread for taking the time to listen to the mix and do the test. As far as the difference being subtle, as I say in the video, to me this was very welcome for several reasons. One obvious one is recalling sessions that were mixed on the TDM system. I have many projects that span several years of work, by having the sonic improvement this subtle, it means that little if any adjustments need to be made when opening a session in HDX that was last saved in HD (plug-in compatibility withstanding). Also, I think that if the difference was huge, on an aesthetic level, it could potentially cause more problems in making the transition to HDX for people, myself included, in terms of just getting used to the sound. Putting the sonic difference aside for a minute, to me, the number one reason to upgrade is the power. 5x more power is significant, and in some cases will allow the difference of being able to run an entire project at 96k, without having to convert down for lack of power reasons. That alone is massive for me, and when you add in the sonic improvement, its pretty hard to resist. I do grant you that the plug-in compatibility issues are real and frustrating me as well. However, I see this all shaking in the next few months. In the circles I work in PT is ubiquitous. Pro PT users spend money to have great tools. If some companies decide, for whatever reason, to not play ball with AAX, I trust there will be equally capable companies willing and desirous to fill that void. Softube, for instance, is doing a fantastic job right now. As far as what plugs I used on the mix, here is a list. Wherever possible I used plug-ins that had both a TDM and HDX DSP version. This made it so that the sessions were somewhere around 75% DSP. Avid: EQ3, Dyn3, Time Adjuster, Revibe, Reverb One, Reel Tape Saturation and Delay, Slap Delay, BF76, Maxim AIR: Distortion, Filter Gate, Vintage Filter, Freq Shifter, Phaser McDSP: 4030, AC202, CB101, 6030, Metric Halo: Channel Strip 3, Multiband Dynamics, Character Softube: Tube-Tech PE 1C, FET Compressor, Trident A-Range, Summit EQF-100 |
#22
I just tried to access the files via the web-page, and it is telling me "not a valid answer" to the question "do you want an Avid rep to contact you?"
i keyed in 'no.' i tried both FireFox and Safari on Mac. could not access files. |
#23
I agree with you on the subtle difference being perfect for swapping a session from HD and HDX did you remix this for the test so you could use plugs that were both TDM and AAX or is it the same mix that's on the album. By the way love the mix and the production and i am a big Lost Prophets fan
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
#24
It said that to me so I just chose yes
Raoul Crane
#25
Raoul23,
I remixed it for this test. The album version had too many plugs that did not have an AAX DSP version. I like all three versions, but I have to say, my favorite is the HDX mix. I'm sure part of this is due to the fact that I was basically mixing the song for a second time, which kind of gave this new mix a bit of advantage. |
#26
Thank you very much for sharing all the info from the session, I Lovd all this knowledge
Raoul Crane
#27
This was totally fun to listen to. Thanks guys. BUT, I would love to hear this done with more dynamic, more sonically challenging material. A classical piece of music or modern soundtrack cue mix might be more revealing.
On the other hand, there's a zero-percent chance that I'm going to stop using my HD|Native system and move to HD|Accel, so these comparisons are moot for me...
Nathaniel Reichman Producer/Re-recording Mixer - New York Nathaniel Reichman | IMDB | LinkedIn |
#28
Raoul Crane
#29
I picked the HDX mixed 5 time after A/B soloing different parts of the song.
The difference is not huge but i could hear a slight more clarity . As for using 88.2k or 96k I'm still ironing the bugs in HDX to go all out with it. PS: the questions on the site to download the files don't make sense if you already own an HDX system
PT 2023-12 ultimate -HDX1- OSX 13.6.1- MacPro 7.1 - D-command 24- Trinnov Dmon6 |
#30
Sorry about that… they are working on it as we speak. The work around is just say 'yes' to be contacted by an Avid rep… I'll try to make sure no-one who signs up in the first few days gets a call… Best and Thanks, Tom
Tom Graham Avid Audio Marketing Pro Audio and Mixing [email protected] Check out our Pro Mixing Webinars : http://www.avid.com/US/resources/pro-mixing-webinars Avid Pro Mixing Blog: http://www.avidblogs.com/promixing/ |
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 03:04 PM |
HD6 vs HDX2 "ITB" Listening Challenge | Tom Graham | Pro Tools TDM Systems (Mac) | 0 | 11-01-2012 08:17 PM |
Pro Tools 9 "Pausing" when I press "Play" with Focusrite Scarlett interface | eanderso22304 | macOS | 3 | 11-23-2011 06:45 AM |
hardware buttons for "preview", "capture" and "punch" | evs | Post - Surround - Video | 1 | 12-06-2010 12:28 PM |
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... | leon777 | Pro Tools TDM Systems (Mac) | 21 | 10-15-2002 12:00 AM |
