Old 06-10-2012, 07:55 PM
trombino trombino is offline
Default HDX + Radeon 5780 = You're screwed
So apparently those of us who chose to factory upgrade our video cards by Apple when we bought our macs a few years ago are SOL when it comes to HDX? Are we really expected to spend another $240 to downgrade our video cards? This seems outrageous to me. Are there any workarounds or should I go ahead and return the HDX card and 16x16 interface I just bought?
My machine is using all the SATA bays so some sort of SATA power cable isn't an option. I am also using two optical drives. If anyone has any ideas for me to try (short of getting an external power supply) I would love to hear them. Thanks!
Mark
Old 06-11-2012, 04:33 AM
Drew Mazurek's Avatar
Default Re: HDX + Radeon 5780 = You're screwed
Problem solved!!
or you could just trade out the video card. I bet someone would swap with you and they'd make out. Why upgrade the video card on a PT machine anyway? I would think only gamers and maybe video editors would do that.
www.drewmazurek.com
Old 06-11-2012, 04:50 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Hi. Same situation, However the folks over at PowerMax linked me this solution.
Vid Power splitter cable for $17.00 or so.
I Have not tried this yet (Pending HDX) but if you do, please post install ease and POV.
T
http://www.powermax.com/parts/show/sta-pciexsplit6
PS. For those with HDX, does this seem to be the correct connection?
Old 06-11-2012, 09:49 AM
That Startech cable the only splitter I've found, too, but the connectors are backwards. We need one that is female to two male.
Anyone know a company that can build one of these things to order? I'm not sure either the Radeon or HDX card could function without a full 12v, but I'd be willing to try.
Mark
Old 06-11-2012, 11:23 AM
necjamc necjamc is offline
Default
If you have the part numbers and specs perhaps this company would do it for you. http://www.v-tron.com/. I have no idea if they would do a per unit sale but worth a shot. I worked here about 20 years ago and they made cables for everything g under the sun. So I'm sure they are capable. Shot in the dark :)
Old 06-12-2012, 10:11 AM
DetroitT's Avatar
The HDX install guide looks as if the card accepts a female, Motherboard male, video card female. So the star tech seems correct if 6" is long enough.
Can anyone confirm?
http://akmedia.digidesign.com/suppor...etup_75289.pdf
Old 06-12-2012, 01:10 PM
I might be calling a male connector female and vice versa, but I can confirm that the startech is backwards from what we need.
The connector on the radeon card itself is not the same as on the motherboard - it's 6 pin but substantially larger. The connector on the HDX card is quite different as well. So we can't use the startech to go directly from the motherboard to either card, we need to use the supplied adapter cables.
Basically, whatever connector is on the motherboard, we need to provide two of those. If the connectors on the startech were reversed, it would be perfect.
Mark
Old 06-13-2012, 10:45 AM
DetroitT's Avatar
Duly Noted!
Avid Please note and include power splitting adaptors. Or make some appropriately available.
Thank you.
+1
Old 06-13-2012, 11:07 AM
TOM@METRO's Avatar
Wink Re: HDX + Radeon 5780 = You're screwed
Originally Posted by DetroitT View Post
Duly Noted!
Thank you.
+1
This is a very reasonable request. I hope Avid is listening.
Every roadblock to a successful HDX installation is potentially damaging to sales, and we need a substantial HDX user base in order to grow our 3rd party PI inventory.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 06-16-2012, 03:11 AM
DetroitT's Avatar
OK.
Opinions welcome. (Avid needs to chime in here as to power detail Safety)
We know this is non-supported. We also know we work with Video needs for our audio.
Scenario:
Mac Pro 5,1 dual 6 core. Radion 5870 twin power video card.
The hopeful Safe Cure (?):
1- PCIEXSPLIT6 PCI Express power splitter cable (6-pin to 6-pin) ($15.00)
HDX Cable to Mac FIRST into the above cable. the Y cable then into the Mac and
Video Card (Power a)
2. Second Video card power direct to mac.
3. Y Cable Length: 6" (Is this enough?)
4. Here is a sketch
Am I screwed here? kemwelch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-04-2013 02:38 PM
ATI Radeon® Xpress 200M Chipset ATI Radeon® Xpress Tracy Lowery 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-26-2006 12:00 PM
I think I screwed up? macr0w 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-29-2004 04:12 PM
I Screwed It Up hookiefree 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-02-2003 06:19 AM
did i get screwed? Jbrooklyn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 03-06-2003 07:03 PM
