Delay comp when overdubbing drums?
For some reason I can't wrap my head around the logic of this. I have a tune which is all tracked, with plugins on all the tracks, pretty much mixed, but I've decided to replace the sampled drums with a live drummer. When I track him do I turn delay compensation on or off? If it's on, and all the other tracks are delayed and lined up then he will play in time with those tracks. But on playback will his new tracks then be delayed thus throwing them out of time?
????????? Thanks, -R
rickkrizman.com |
Re: Delay comp when overdubbing drums?
Everything will be in sync as long as you don't have any high delay inducing plugins on the master fader and are not recording the drum mics through auxes and then bussing them to audio channels.
So leave delay compensation on?
Thanks, -R
rickkrizman.com |
Remember that nutty checkbox in the i/o dialog
`My name is Pro Tools HD, King of Kings: Look on my works, ye mighty, and despair!' Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare, The lone and native DAWs stretch far away. |
Screw it. Leave it off. So much easier.
Pro Tools Tutorials: Mixing Heavy Rock & Metal • Pro Tools 11 - Tips and Tricks • Delay Explained • Tracking Rock - Drums • Mixing Rock • Music Production with Pro Tools • Pro Tools Tips and Tricks Vol. 2 • Pro Tools Tips and Tricks Vol. 3 • Elastic Audio in Action |
What about it?
-R
rickkrizman.com |
To be absolute sure about the timing and to avoid the drummer having to play with delay compensated tracks then turn ADC off, temp disable any plugins that are causing more than about 100 samples delay and especially RTAS plugins on auxes and any plugs on the master bus and record the drums then re-enable the plugs. The drummer won't mind the mix sounding a bit "un-mixed" whilst he is laying his part down.
So that thread refers to checking the box in the I/O setup window that says "Compensate for input (or output) delay after recording pass."
I'm guessing that means that with ADC on (if you have plugins on previously recorded tracks), you'll be hearing tracks late and thus playing to them late. In that case, does checking that box cause your newly recorded track to be moved forward in time by the ADC amount, so that on playback the ADC will delay it (as it delays the other tracks) and it will be in sync with the other tracks? If so, then you should overdub with ADC on and those boxes checked? Not much explanation in the documentation. -R
rickkrizman.com |
We should request a ruling from the bench...
Delay Comp problems again, Delay comp is RED but way below limits. | soundeq | Pro Tools TDM Systems (Mac) | 13 | 11-29-2011 12:01 PM |
Need advice on overdubbing midi drums parts | Hamdi | The Drum Room | 2 | 04-23-2011 08:03 AM |
Overdubbing with Delay Compensation | tim carter | Pro Tools TDM Systems (Mac) | 3 | 08-20-2010 08:35 AM |
Newbie to mbox / PT - delay when overdubbing... | mkalei | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-15-2004 10:09 AM |
delay when overdubbing... | jake blanton | Digidesign Hardware & Software | 2 | 02-22-2001 06:15 PM |
