Old 04-07-2009, 10:44 AM
john a john a is offline
Default Video Satellite image quality question
Hey all- we are running video satellite le on a G5, with the Digi- recommended Blackmagic card. Working on a film for which we have a
DVCPRO HD 720p60 .mov file. Here's the issue we are having - if we play the file using just the Quicktime player, the titles (which are white text against a black background) look very crisp and clear. If we open the app that lets us play the file using just the Blackmagic card, which is paying to a large HD display via HDMI, the titles look the same, very crisp and clear. If we put the exact same file in ProTools and play out through the same Blackmagic card the titles are wildly jaggy and low-res looking.
I am wondering if anyone has had any similar issues, or might have any
secret Video Satellite LE tips....
thanks very much
John A
Old 04-07-2009, 11:36 AM
minister's Avatar
minister minister is offline
Default Re: Video Satellite image quality question
select High Quality Quicktime playback in the prefs.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 04-07-2009, 03:07 PM
Thanks for the response. Did change that pref to High Quality, but see no perceptible change in image quality as a result.
The file also plays fine in Final Cut.
John A
Old 04-07-2009, 03:46 PM
minister's Avatar
Are you going out correct output on the BlackMagic (720p60)?
Tom Hambleton CAS
IMDb
-Starcrash
Old 04-07-2009, 05:17 PM
cjguitar cjguitar is offline
Also, in the System Preferences/Decklink Panel, uncheck "Remove field jitter when video is paused". For us, when it's enabled, it makes all of the edges jagged.
Chris M. Jacobson, CAS
Re-recording Mixer, Sound Designer
IMDB
Old 04-09-2009, 01:03 PM
That did it- thanks very much. Perhaps the preference should say "induce field jitter when video is played"
Looks VERY nice now.
JA
Old 04-09-2009, 02:09 PM
Postman Postman is offline
Sounds like a bug.
Old 04-09-2009, 02:19 PM
dr sound's Avatar
dr sound dr sound is offline
Originally Posted by Postman View Post
Sounds like a bug.
The way Chris (cjguitar) found it is we had the problem with VVTR and the Decklink card. Now that we are on Satellite and the new Decklink HD card we found it is there also. There is a reason for it that escapes me now. It isn't a bug, just a choice.
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
HTML code is On
Video Satellite question TommyT Pro Tools TDM Systems (Mac) 2 08-03-2011 09:23 AM
Video Satellite LE - Enable Satellite Mode is greyed out? Erik Olsson Post - Surround - Video 6 01-11-2010 09:16 AM
Video Satellite LE sync question vudoo Post - Surround - Video 2 09-23-2009 05:35 AM
Video satellite question DavidHeylen Post - Surround - Video 4 06-13-2008 11:05 AM
Video Satellite workflow question JC925602 Post - Surround - Video 3 04-10-2008 05:09 PM
