old g4/001/macos10.3.9 maor problem.....
hello all i am engineer/ tech from hollyweird and i am trying to help a fried of mine, my friend has an old g4 400 tower and is using a 001 with os10.3.9, whats weird is that although the cpu works great,pro tools boots fine, but when i try to open a session i get this shaded translucent screen that informs me that i must turn off my computer now.....i hve tried to re-install both os and protools to no avail,as well as using my own 001 cable,and finally i believed that maybe there is a corrupted ram stick and there is 448meg of ram in the box and i have tried swapping the ram sticks at all configuration again to no avail.....i know this an almost archaic system and that maks findind info for it all the more difficult, but PLEASE if any one knows whats happening please let me know, and thank you in advance............
Re: old g4/001/macos10.3.9 maor problem.....
HI,
are you using PTLE 6.4cs9? if not do so. and no QT7.x stay with 6.5.2. regs
last: PT11.3.1 |
PTLE 6.4 is only officially supported with 10.3.8. That said I'm using 10.3.9 with no problems, but I'm using QuickTime 6.5.2. QT7 is a no-go.
You can run Panther/6.4 on a 400mhz, but it runs out of steam pretty quick. You'd be better off running 5.1.1 on OS9 if you need a decent sized track/plug count. |
I remember I had loads of problems with 10.3.9. Use 10.3.8 or maybe 10.4.1 if supported.
I was using 10.3.9 on my G5, but I don't think it was ever officially supported by Digi.
Larry PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins. |
Ya Core Audio just plain sucks in 10.3.9 - I had much better luck with 10.3.8 too. I'm not sure what Apple was thinking with 10.3.9 but it broke more audio programs than fixed for me. And then Tiger fixed many of those issues that 10.3.9 had.
So revert to 10.3.8 and Quicktime 6.5.2 if you can. You can use oldapps.com or oldversions.com to get older versions of Quicktime I believe. Good Luck! |
Which version of CAD were you using? 6.9 works for me with the caveat that with some apps like GarageBand you need to launch CAD first or you get no sound.
YMMV. Hope this helps.
i7 Mini, 002R, OSX10.7.4, PT10 |
Problem with Pro Tools 9 and Profire 2626. Anybody have a solution to this problem? | Priz | Windows | 1 | 09-25-2011 12:51 PM |
Cracks on PT9.0.3 with Digi003 and MacOS10.6.7 | icisoundstudio | macOS | 1 | 06-16-2011 01:58 PM |
ELS Vocoder plugin problem and fresh Windows 7 install problem | Thorpey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-09-2011 05:03 AM |
Need opinions: Do I have Core card problem or computer problem? | johnnyv | Pro Tools TDM Systems (Mac) | 2 | 08-11-2010 06:36 PM |
digi 002/7.4 installation problem/not recordable volume problem | fifthflaw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-08-2008 01:28 PM |
