Old 05-25-2006, 02:22 PM
sethbrand sethbrand is offline
Default Has anyone figured this out yet?
I have an m-audio firewire 1814, pro tools m-powered 7, my laptop, and an external hard drive. I was wondering if anyone ever figured out why when i daisy chain my equipment i get popping noises while recording. I hook my external hard drive to my laptop via firewire and then my m-audio 1814 to my external hard drive. When I open a session from my external hard drive, i get popping while recording. So i have to save a copy of the session to my computers h/d and then record from there, which really sux. Is there a way to fix the popping so i can work from my external?????
Seth
Old 05-26-2006, 05:11 AM
orfeas orfeas is offline
Default Re: Has anyone figured this out yet?
I ran into a similar problem, not sure if it is what you are experiencing. I have a Dell Inspiron 6000 and an external Acomdata E5 drive with both Firewire and USB 2.0 ports. I first started using it via its Firewire port but would get bursts of static recorded on all tracks every second or so. I noticed this coincided with the drive's light going on, so basically every time something was being written to the hard drive, it made noise that got onto the Firewire bus somehow.
I solved it by switching to the USB 2.0 port for the Hard drive. I don't know if it is the Acomdata drive's Firewire port that is noisy or if it is my Dell's port, but the problem went away with the USB 2.0 port, which is just as fast anyway. Hope this helps.
Old 05-26-2006, 03:17 PM
jp_dt jp_dt is offline
I'm running a fw410 connected to a dell latitude d505 (1.4g celeron). I've tried connecting different orders and also different pcmcia card adapters. I have the same problems, have discussed them here, and with the m-audio online support. M-audio says I'm overloading the 1394 bus, which seems hard to beleive since that config works fine when connected to my ibook g3 900. They did suggest recording to a usb 2.0 drive, i've been recording to the internal (super slow) drive. Maybe it's the MS implementation 1394; who knows?? Wish I could say, "Yes, I had that problem, here's how I fixed it."
spkguitar says his setup works, but I can't recall what his system is. He posts quit a bit in these parts.
Old 05-26-2006, 05:00 PM
spkguitar's Avatar
It seems like it might be a problem with that particiular hardware; the 1814 or the fw410.
I have the Ozonic; hooks up via firewire, and I daisy chain it thusly: PC->hard drive->Ozonic.
I don't own the 1814, but I have had one hooked up to my system (I have a friend who has one) and I didn't have the problems mentioned in these threads.
It is very important that the firewire drive have the Oxford 911 firewire chipset.
Old 05-27-2006, 08:41 PM
Hi spkguitar,
Thanks for chiming in on this again. I do indeed have the oxford 911 chipset. Was your friend's system a laptop or tower?
Old 05-27-2006, 10:15 PM
mrufino1 mrufino1 is offline
I went through this with my 1814 and emachies 6805. Using a usb2 hard drive solves the problem. I think it is terrible that a firewire drive won't work on the same bus, but for now I have to go along wiht it until they find a fix. I bought a pcmcia card with the TI chipset as they suggested, and I can actaully run a firewire drive off of there and the 1814 on the built in firewire port of the laptop, but since I know the usb 2 works and I mostly record live shows with no chance to fix a messed up recording, I don't try it. But usb 2 uses mroe processor power than firewire, so when I am mixing I usually use it as firewire. If you search my posts on this from a few months ago you'll read the whole saga...
Old 05-28-2006, 06:05 AM
spkguitar's Avatar
Hi spkguitar,
My friend uses his with a laptop; the Gateway that is almost identical to the m6811 that I have (I forget the model number). But I had it hooked up to my m6811 laptop as well. We were using the built in firewire interface on both laptops. No problems.
So i think i figured out what i'm going to do .... chazzo03 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-23-2008 12:03 AM
figured out latigo and PTs Rezdog MIDI 0 08-01-2005 01:44 PM
Figured out problem..... beatledude Pro Tools TDM Systems (Win) 1 03-11-2004 11:52 AM
I figured the DUC might like this PlugInJunky Pro Tools TDM Systems (Mac) 2 08-23-2002 06:27 PM
I finally figured it out!!! Kenny Gioia Tips & Tricks 14 04-26-2002 06:40 PM
