Removing harshness from muted trumpets on HD system
I'm mixing some library music on my HD-3 system that has a track of harmon-muted solo trumpet, and being an engineer by necessity(and not by trade), I was wondering if there are a couple of kind souls who could assist me in the fine art of removing it's inherent harshness. It was recorded well(performed beautifully), in a pro studio with a U-87 at a distance of about two feet, with no eq and minimal compression.
There seem to be two offending frequencies: 1. A brittle, spit-your-head-in-half shrillness somewhere in the over 1k range, and 2. A harsh, grungy sound somewhere below that(it seems to be player generated, this has been a sound that seems to vary from player to player in my experience). Any insight into this would be greatly appreciated(also alternate mic choices for the future would also be welcome).
a $120k business degree will get you a job on Wall Street - a $120k Berklee degree will get you a job on Beale Street... |
Re: Removing harshness from muted trumpets on HD system
it's the mic. try doing a hi cut at 7 or 8 k. then bring some 10 k back. you might be stuck with wahat ever your hearing at 1k.
For the piercing high problem I would use a multiband comp- C4 or the McDSP one. The C4 should
do pretty well- Best thing would probably have been to use a ribbon to begin with; or record with eq and compression! I compress the p out of trumpets generally, Harmon mute or no. |
Thanks for your replies.
Is it that ribbon mics have a more pleasing frequency response to a muted trumpet, or is the mechanics of the mic? I'll try the 7-8k cut, 10k add and see what happens.
RECORDING AND MIXING TRUMPETS IN SALSA MUSIC | nachonieto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-22-2007 08:27 PM |
Completely removing Pro Tools from my system | JonB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 10-01-2005 10:15 PM |
harshness in recordings | rems | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 04-15-2003 09:09 AM |
trumpets | ethical | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-03-2002 02:56 PM |
SUGGESTIONS FOR REMOVING UNNECESSARY SYSTEM ITEMS!?!?! | pobox7310 | Pro Tools TDM Systems (Mac) | 3 | 11-25-2000 12:36 AM |
