Copy selection to target/main playlist not working in waveform view?
I tried option-shift-up and control-option-v. Both work in playlist view. Neither work in waveform view. What gives?
Also, I watched this tutorial: https://www.pro-tools-expert.com/hom...pro-tools-2018 He says you can scroll thru playlists with an edit selection via command-shift-up/down and then copy to main playlist with one of those shortcuts. Is that last part redundant though? Even in his video, you already see the clip in the main/target playlist is split at the edit selection and contains the alternative content. I can move the cursor someplace else, and the transplanted clip is still there. So is there a need for option-shift-up when you use command-shift-up/down to scroll thru alternate playlist selections? (2019.6) |
Show Target Playlist(s) After Sending Clip Selection (???) | EdgarRothermich | Pro Tools 2019 | 2 | 07-17-2019 04:41 PM |
Copy Selection to Main Playlist bug - can you check if PT 12 has it too? | jacko | Pro Tools 12 | 1 | 07-27-2015 11:40 PM |
Vertical Jumping With Edit Selection In Playlist View | soundlabyrinth | macOS | 11 | 09-24-2012 06:37 PM |
Toggle Track View not working (waveform/volume/etc) | Imgoinmad | Pro Tools 9 | 4 | 11-24-2010 04:35 PM |
