Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 07-30-2018, 04:38 PM
Fuzzyc Fuzzyc is offline
Default CPU spikes after installing under a new Windows user ID
I was just force to create a new Windows user ID and installed Pro Tools 2018 under that new user. If I sign into the original user ID and run PT, everything is fine. If I sign into the new user ID, PT doesn't work. I get CPU spikes on all processors up to 100%. So all you hear is noise (click, pops, etc). So my system is totally unusable now. Has anyone ever installed PT under a new Windows user ID? Is there a step I'm missing other than simply uninstalling PT and then installing it under the new user ID? I'm dead in the water now. I called PT support and they created a ticket for this case mid-day on Saturday. Haven't heard a word from anyone since. Any help would be much appreciated!
Thanks!
Model: PC Audio Labs Rok Box i5
OS: Windows 10 64 Bit
CPU: Intel® 2.66GHz Quad-Core Intel Core i5-750
Memory: 16GB
Internal Hard Drives:
250GB= Progams
500GB= Audio
500GB= Samples/Back Up
External Hard Drives: Verbatim 1TB USB Drive
RME Fireface UFX Interface/Preamps
Pro Tools 2018.4
Focal CMS 65 Monitors
Avantone Monitors
Old 07-30-2018, 07:51 PM
albee1952 albee1952 is online now
Default Re: CPU spikes after installing under a new Windows user ID
Did you run the installer as administrator? Are you running Pro Tools as administrator? You should do both
Old 07-31-2018, 02:42 AM
chrisdee's Avatar
chrisdee chrisdee is offline
In addition to what's suggested above have you tried deleting the Pro Tools preferences?
Old 08-01-2018, 05:54 PM
Thanks for the tip. I actually had already tried that. Turns out I finally got someone at Avid to find and fix the problem. I had a bad outing in my I/O settings. Live and learn!
Thanks!
Memory: 16GB
250GB= Progams
500GB= Audio
Pro Tools 2018.4
Avantone Monitors
Windows users with CPU spikes/errors 12.5 59.9hz Pro Tools 12 54 09-03-2017 02:03 PM
Speakerphone CPU Spikes after upgrade to Windows 8.1 seanmccoy Pro Tools 10 0 08-14-2014 12:01 PM
Pro Tools not installing from primary user account (again?) silence2-38554 macOS 0 07-16-2013 09:05 PM
PT 9 and Windows 7 major CPU spike fix!! PT 9 bug, with fix. Every Windows user!! Will The Weirdo Windows 4 01-19-2011 01:37 PM
Pro Tools System Usage CPU monitor Spikes but not Windows Sherbert99 Pro Tools M-Powered (Win) 0 05-28-2008 08:18 PM
