Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 05-09-2018, 08:03 PM
Protu Protu is offline
Default Could not create New Doc. Too Many Levels
I hope this is an easy fix Here is my error message.
Could not create a new document because Too many levels of symbolic links (62) while creating "session name here"
I totally deleted Protools off my mac. Then reinstalled everything. Everything was working great then i got this error. I tried deleting the prefs first. Then i deleted everything. All prefs, plugs, everyfile i could find related to Digidesign and Avid. I downloaded everything and reinstalled it. Still the same error. I have no symbolic links everything is installed on the local hardrive.
MacOS High Sierrra
10.13.3
Universal Audio Apollo twin
Macbook Mid 2015
Old 05-09-2018, 08:16 PM
Default Re: Could not create New Doc. Too Many Levels
i fixed it. When i had Location selected as the place to save the document i got the error. When i switched it to prompt for location protools loaded fine. So, I selected location again but changed the folder to a hard drive and it worked. I switched it back to the Users/yourname/documents.. I got the error again
This is apples fault. Thats my story and im sticking to it.
Old 05-10-2018, 08:59 AM
ehaber ehaber is offline
Don't think it's an issue with Macs per se. I've run into a similar issue with PCs. Basically, there's a limitation of the numbers of characters (letters/numbers/punctuation marks, etc.) you can have in a series of folders and subfolders. Therefore, if your folder has a long name and then you have subfolder with a long name, etc., at some point the operating system won't let you add a file to the end subfolder because the total path has two many characters. Sounds like what you're seeing here.
Create Project vs. Create Sessions metalmixer Getting Started 2 09-12-2016 09:55 AM
Tracking Levels and Playback Levels paul_g 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 11-26-2010 06:37 PM
Creating the best mix levels / playback levels universe777 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-25-2006 11:49 PM
Broadcast levels vs. Podcast levels... McBoob Post - Surround - Video 0 05-05-2006 09:03 AM
Linking track levels w/ pre-fader bus levels? Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-07-2003 11:36 PM
