Old 03-21-2017, 05:48 AM
zejuju zejuju is offline
Default numbers of assign in EUcon
Hi
I'm using artist mix with eucon (3.5 version).
I can't find how to assign more than 8 strips in the eucon assign menu.
I figure that's possible, but how?
And when in assign mode, you can't anymore go through banks9-16 or any more than 8 on the artist mix...
Old 03-22-2017, 10:33 AM
EddieJones's Avatar
Default Re: numbers of assign in EUcon
You could never go past the number of Physical strips (pretty sure :-/) This is an S6 feature.
Old 03-23-2017, 02:13 AM
ok...strange limitation! I mean this is not useful as you can have several banks when strips are not assigned...
So it might work just for busses, Am I right?
Do you plan to make it better for the artist mix?
I can figure that's just code issue, as the hardware can make it right
Old 03-23-2017, 10:02 AM
EddieJones's Avatar
You would use Layouts to assign more strips and switch between them.
Old 03-23-2017, 10:13 AM
I agree that's a kind of a solution, not an easy one.
Why not just improve eucon for artists mix?
Old 03-23-2017, 10:21 AM
EddieJones's Avatar
I will bare this in mind for a future update.
Old 03-23-2017, 10:24 AM
Thanks for your quick answers!
EuCon suddenly broken - Eucon client can not access the bonjour service noiseboyuk Artist Series 0 04-12-2016 01:34 PM
EUCON 3.3.1 Won't assign wheel commands to Transport jog/shuttle JWalkerPostAudio Artist Series 0 09-16-2015 12:43 AM
Eucon 3.2.2 installer error + firmware downwards compatible with eucon 3.1 deauditievedienst Artist Series 0 08-05-2015 03:09 AM
Artsits Control ASSIGN/Select Button: is there that Command in the Eucon List?? AMIEL Artist Series 0 02-04-2015 08:52 PM
