Old 06-12-2011, 07:03 PM
harryk harryk is offline
Default No Sound - Mbox 2 - new drivers
I recently updated to PT 9.0.3 with the 8.0.4.354 Mbox2 driver. All sessions were working; I was getting sound. I updated to the new Mbox family of drivers and my sessions would play but I would not get any sound. I've reverted to PT 9.0.2 and the 8.0.4.354 drivers and everything is fine.
Anyone else having this problem? Is it possible that the driver was corrupted on download?
SiSoftware Sandra
Computer
Model : Gigabyte X58A-UD3R
Workgroup : WORKGROUP
Host Name : protools-PC
User : protools
Processor
Model : Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz
Speed : 3GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 2 Unit(s)
Type : Quad-Core
Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing
L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing
Computer
Mainboard : Gigabyte X58A-UD3R
BIOS : Award (Phoenix) FE 12/23/2010
Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 12GB DIMM DDR3
Chipset
Model : Giga-Byte X58 I/O Hub
Front Side Bus Speed : 2x 2.4GHz (4.79GHz)
Chipset
Model : Giga-Byte Core Desktop (Bloomfield) UnCore
Channels : 3
Memory Bus Speed : 2x 532MHz (1GHz)
Memory Module(s)
Memory Module : Corsair CMD12GX3M6A1600C8 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5)
Video System
Video Adapter : NVIDIA Quadro FX 380 (Microsoft Corporation - WDDM v1.1) (16 SM4.0 1.1GHz, 256MB DDR3 2x704MHz, PCIe 2.00 x16)
Graphics Processor
Storage Devices
WDC WD5002AALX-00J37A0 (500.1GB, SATA600, 3.5", 7200rpm, NCQ, 32MB Cache) : 466GB (C:) (G:)
WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm, NCQ) : 932GB (F:)
WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm, NCQ) : 932GB (E:)
ATAPI iHAS424 B (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:)
Logical Storage Devices
SysRes (G:) : 100MB (NTFS) @ WDC WD5002AALX-00J37A0 (500.1GB, SATA600, 3.5", 7200rpm, NCQ, 32MB Cache)
samples (F:) : 932GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm, NCQ)
sessions (E:) : 931GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm, NCQ)
Cdrive (C:) : 466GB (NTFS) @ WDC WD5002AALX-00J37A0 (500.1GB, SATA600, 3.5", 7200rpm, NCQ, 32MB Cache)
Optical Drive (D:) : N/A @ ATAPI iHAS424 B (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : Giga-Byte LPC Interface Controller
LPC Legacy Controller 1 : ITE IT8720F
Audio Device : Giga-Byte HD Audio Controller
Disk Controller : Giga-Byte 6 port SATA AHCI Controller
Disk Controller : Giga-Byte 88SE9128 SATA-600 Controller
Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller
USB Controller 1 : Giga-Byte USB UHCI Controller #4
USB Controller 2 : Giga-Byte USB UHCI Controller #5
USB Controller 3 : Giga-Byte USB UHCI Controller #6
USB Controller 4 : Giga-Byte USB EHCI Controller #2
USB Controller 5 : Giga-Byte USB UHCI Controller #1
USB Controller 6 : Giga-Byte USB UHCI Controller #2
USB Controller 7 : Giga-Byte USB UHCI Controller #3
USB Controller 8 : Giga-Byte USB EHCI Controller #1
FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller
SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Network Services
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 4.9
PT 12, Gigabyte GA-X79-UD3 ATX LGA2011 MB,Intel Core i7-3930 3.2GHz 6-Core Processor,Asus NVIDIA GeForce GT 640 2GB GDDR3 PCI-e Video Card, Patriot Viper 3 Low Profile Blue 32GB (4x8GB),Cooler Master Hyper 212 Evo CPU Cooler, Rosewill Stallion Series RD700 700W Power Supply,Western Digital Caviar Black Internal system/session/samples,Windows 7 Professional 64-bit,Mbox2
Old 06-14-2011, 11:12 AM
Default Re: No Sound - Mbox 2 - new drivers
Bump. I find it funny that people responded to Cavalerra about his problem, which sounds similar to mine, and I provided the necessary information.
Old 06-14-2011, 07:12 PM
remis remis is offline
Can you just clarify one thing for me, when you say you treated the driver to "the new family of mbox drivers"...do you mean you installed the drivers for the mbox 3? If I read that correctly then I'd imagine that's your problem as they're completely different interfaces and you can't just swap the driver. You'd need to use the specific "mbox2" driver.
PT10, Focusrite Liquid Saffire 56, Eleven Rack, i7 950 @3.80GHz, Noctua NH-D14 CPU cooler, GA-X58A-UD3R, Corsair CMD12GX3M6A1600C8 12GB, SAPPHIRE VAPOR-X HD5770 1GB GDDR5 PCIE, Caviar Black 500GB 32MB Cache OS drive, 2x Caviar Black 1TB 64MB Cache Sata3 (Audio and library), Broadcom BCM94322MC wireless network adapter
W7 - 312 dverbs @ 64 buffer/ 403 dverbs @ 1024
Old 06-14-2011, 09:04 PM
Remis, thanks for replying. Let me clarify. I updated the Mbox2 drivers and had this problem.
Old 06-15-2011, 08:39 AM
Ah ok, thanks for clarifying. I had a similar issue with my Mbox2 Pro...strangely I found that there was one certain session I needed to open in order to get the sound to engage. I'm not sure whether it had something to do with clock settings or anything now that PT is seperate from the interface...but for me that seemed to work. If I opened that one session I would hear a slight pop as if the mbox had kicked into life, yet if I opened any other session I had the same issue as you...the session would play and the meters were jumpin' but I'd have no sound...I tried asking about this on here to see if DTS or someone from Avid would have any ideas, but got no response.
Hope you find a solution Harry.
Old 06-15-2011, 09:12 AM
Remis thanks, what did you end up doing? Did opening that one session fix the problem for all of your sessions that lost sound?
Also, it seems like the problem is related to the new drivers and not PT 9.0.3. I upgraded again to PT 9.0.3 without upgrading to the new drivers and I don't have the problem. Although, I'm starting to have more -6085 errors now with 9.0.3. I've changed the usb connection to every other usb connection on the computer without success on that one.The clock is still set to internal and the sample rate is 44.1kHz.
I will try upgrading to the new drivers later after I finish some sessions and see what happens. Maybe, that will fix the -6085 errors. If not, it's back to PT 9.0.2 with the old drivers for now.
Old 06-15-2011, 09:16 AM
For me, if I opened that one session that gave me sound I could then close it and open up any other session and the sound worked fine...it seemed like it just needed something from that session that made it jump to life. Only reason I brought up the clock settings is because that session was at 48kHz and was an older session, where as most of my new sessions are 44.1kHz...just the way my new interface (Focusrite Liquid Saffire 56) deals with clock settings made me curious as to if this may have had some effect...but again I have no idea what caused it, and it seemed at the time no one on here had any ideas either.
But yeah, if I opened that one session that egnaged the sound I was then free to open any session I wanted and it would work fine.
Old 06-15-2011, 09:22 AM
Just to be clear, my mbox 2 was the pro model that ran via firewire. Also, as a check, have you applied the optimizations suggested by Avid for Windows 7 users? Specifically the ones relating to USB power settings? Not sure if this would cause something like this...but I suppose anything's possible.
If not, the optimizations can be found here.
Old 06-15-2011, 09:26 AM
I definitely went through the optimization guide and everything is set as explained there.
I will have to check the session sample rate and see if that might be the problem. I usually run the sessions at 44.1 but I seem to remember that after upgrading to PT 9 some of the new sessions defaulted to 48. uhmmmmm.
Once again, thanks for your help.
Old 06-15-2011, 01:22 PM
Smile Re: No Sound - Mbox 2 - new drivers
Update: upgraded the Mbox 2 drivers with the 9.0.2.65 version and was still getting -6085 errors. So, I moved my USB connection from the 3.0 usb connection on the MB to the 2.0 usb connection for the Mbox2. Now the -6085 errors are gone... I haven't found any information saying NOT to use the 3.0 usb connections for the Mbox2. However, that may have been the problem. It would seem like a faster connection would be better but maybe it's not in this case.
With that said, the ghost in my machine has left the premises, at least for the moment.
No sound from Mbox 3 Pro after updating drivers Kanosan FireWire and USB Audio Interfaces (Mac) 13 11-11-2013 06:33 AM
Mbox 2 mini. DRIVERS sound/no sound HotLava 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-17-2008 07:52 AM
Help with Sound Drivers twilightlies 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-19-2008 12:09 PM
Sound Drivers Gone Again! SteveGarman Pro Tools TDM Systems (Mac) 0 02-09-2000 09:19 PM
Sound Drivers Songtree Productions Digidesign Hardware & Software 1 06-25-1998 12:20 PM
