Old 02-25-2010, 06:07 AM
anodecathode anodecathode is offline
Default Kontakt 4.0.5 rtas plug-in causing some anomalies in Pro Tools HD 8.0.3
I'm noticing some odd behavior in Protools with Kontakt 4. When I place the Kontakt 4.0.5 plug-in in the Pro Tools 8.0.3 plug-in folder and launch Pro Tools, it causes some strange anomalies. If I try to drag audio from mac finder into the edit window I get a spinning beach ball for about 15 seconds, then the waveform appears. I also noticed that a to z is disabled and cannot be re-enabled unless I shut down Pro Tools and restart. The problems will continue until I remove the Kontakt plug-in, delete the prefs, then zap the pram. All is back to normal if I do this. Anyone else experiencing this kind of erratic behavior with Kontakt 4 in Pro Tools HD?
2009 Mac Pro Nehalem 2 X 2.26GHz Quad-Core Intel Xeon - OS 10.9.5 Mavericks - 128GB ram
ProTools TDM HD6 - Magma Expansion Chasis - PT 10.3.8 and Avid I/O.
ProTools 12.7.1.733
Macbook Pro 2.66GHz Intel Core 2 Duo OS 10.9.5
ProTools 12.7.1.733
Mbox2 PT 10.2
Scott Whittier
Whittier Creative
http://www.madmix.com/
www.voice123.com/scottwhittier
Old 02-25-2010, 08:00 AM
relaxo relaxo is offline
Default Re: Kontakt 4.0.5 rtas plug-in causing some anomalies in Pro Tools HD 8.0.3
WHAT?!? You don't say! A Native-Instruments plugin that's buggy?!?
Impossible!!!
Native Instruments product have the finest coding ever written and the most courteous and caring support staff behind them ever assembled!
For fairness sake, Kontakt is one of the best and most powerful VIs ever made...when it's working. However, personally, I find AIRs VIs to be thicker, richer, creamier...much more so in fact. NI VIs don't sound good to me in general...they sound hard and thin. (I do kinda like the B4 II)
Old 02-25-2010, 08:06 AM
x9blade x9blade is offline
k4.0.5 has been,i'm afraid to say....... stable on my hd rig. seems like as of late all ni product have come a long way as far as stability goes. appluads to them
maybe its a computer config problem
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4
32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE
Old 02-25-2010, 09:05 AM
ronwasserman's Avatar
ronwasserman ronwasserman is offline
rock solid here as well.
Ron Wasserman
http://www.ronw.com
http://www.imdb.me/ronwasserman
http://www.fishertheband.com
Mac Pro (Late 2013) 3.5 GHz 6-core Intel Xeon E5 - 32 GB Ram / 1TB Flash Storage - Avid HD I/O - Latest Mac OS - HDX3 - Latest PT Version.
Old 02-25-2010, 09:40 AM
Yea, it's rock solid on my end too, with the exception of this one problem which is kinda annoying. The only time it acts up is if I drag files from finder into the edit window so I'm not sure what settings would agitate that. Strange thing is, if I import the files with apple+shift+I the audio comes in without a hiccup.
So you and Ron have both dragged files from finder into your edit window with no problem? Also, I'm on 8.0.3 not the cs1 version.
Thanks for your help with this.
ProTools 12.7.1.733
ProTools 12.7.1.733
Mbox2 PT 10.2
Scott Whittier
Whittier Creative
Plug ins Missing (Kontakt, POD Farm) from Pro Tools 10 Plug-in list smythmakesmusic macOS 28 05-13-2017 04:41 AM
Kontakt 4 RTAS... 64 bit? GordonFreeman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-26-2010 09:12 PM
Dverb causing RTAS usage spike. DJ Hellfire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-30-2010 06:48 AM
Kontakt 2 Stand Alone vs RTAS, Kontakt vs Giga ryan de topanga Pro Tools TDM Systems (Mac) 18 05-17-2005 06:36 AM
Pro Tools LE RTAS plug-in Allbizzniss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-11-2003 04:35 PM
