Old 08-03-2009, 02:26 AM
Bobbysweden Bobbysweden is offline
Default D-command question
Hi
Is there any way to route the system so "out 1-2" goes to L-R
By default 1-5 goes to L-R main
I have people in my studio that works in Logic .. and.. as it is now . they only hear one channel .. is there a solution for this ?
Best
B
Old 08-03-2009, 06:11 AM
digimidi's Avatar
digimidi digimidi is offline
Default Re: D-command question
The easiest way to do this is to "crosspatch" the connection between your main interface and the X-Mon. Using the 192 I/O as an example, take ch 1-2 of a D-sub to XLRM out of the 192 and patch them to the 1-5 inputs of a D-sub to XLRF into the Main input of X-Mon. If you are using a patchbay, you can also wire it permanently there.
Gil
Gil Gowing
Principal
Digimidi Technical Services
Old 08-04-2009, 01:23 AM
Thanks !!
That should do it .
Best
B
D command CF question uno1234 ICON & C|24 7 10-27-2010 04:26 AM
Key Command Question. philip888 General Discussion 2 08-26-2010 01:58 AM
Command 8 Question Wyn ProControl, Control|24, Command|8 0 06-28-2010 06:31 PM
Command 8 question Adamsound Pro Tools TDM Systems (Mac) 0 04-22-2004 10:22 AM
Command question Drive d 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-23-2003 05:14 PM
