Old 02-21-2015, 07:58 PM
Paul Cavins Paul Cavins is offline
Default FW drive won't mount when 002R is on
Hello-
I've had an 002R for years, and have used it with OWC FW drives, connected properly, iMac-FW drive- 002R.
Recently, I can't get the drive to mount when the 002 is connected and turned on.
Without the 002, the drive mounts normally.
When things aren't working, in System Report on the iMac, I get a message that reads "Unable to list firewire devices".
Thanks-
PC
I don't know karate but I know KA-RAZY!
Old 02-22-2015, 01:24 PM
Default Re: FW drive won't mount when 002R is on
With any 002, I suspect the power harness. Unplug(NEVER connect or disconnect the FW cable with things powered ON) the 002 and remove the top panel. With the unit facing you, the PSU is on the right side. Remove and reconnect both plastic connections on the PSU several times each(5-6 times minimum). Now trace the harness from the PSU to 2 circuit boards and work those connections the same(off and on at least 6 times). This is to scrape thru the oxidation that builds up on the pins and sockets. Replace the top, reconnect and cross your fingers
Old 02-22-2015, 01:43 PM
And maybe try a little Deoxit on the connectors. http://www.amazon.com/gp/product/B0002BBVN2
Old 02-22-2015, 05:51 PM
Thanks for the input. I'll give that a try--
I did go through the faulty power harness thing years back. This sound different--
Thanks--
PC
Old 02-28-2015, 12:09 PM
Crap. I cleaned the power harness, at least at the entry part.
Further investigation leads me in a different direction.
After cleaning, still behaved the same. Checked cables.
I connected the 002r to the iMac directly via the FW800 to 400 cable. It worked.
Then I used a different drive with 002r. Still didn't work.
THEN tried to daisy-chain two FW drives together and they did NOT mount to the desktop.
So maybe my FW port isn't giving out enough juice?
Both drives are powered by wall-warts.
THanks--
PC
Drive Won't Mount sky88dd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-28-2009 06:01 AM
FW Drive won't mount Tim R. Pro Tools TDM Systems (Mac) 12 10-20-2004 01:19 PM
OT: OWC Drive won't mount HELP!!! Psax2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 07-25-2003 07:08 PM
OT: OWC Drive won't mount HELP!!! Psax2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-25-2003 06:33 PM
UW Atto does not Mount Drive Applebee Pro Tools TDM Systems (Mac) 3 04-25-2001 10:06 AM
