  #241
Old 01-16-2012, 02:18 PM
wolfdavis wolfdavis is offline
Default Re: "Some regions had invalid bounds and were adjusted or deleted"
Originally Posted by DigiTechSupt View Post
The 8.0.5, 8.1.1 and 9.0.2 releases fix this issue - the incorrect error message about some regions had invalid bounds...
Just had a system create this error message today. Immediately after removing the flash drive which the audio files were copied from. Here's the path of destruction: Audio files exported from Nuendo => Copied to flash drive => Files copied from flash drive to regions bin directly with auto copy on import on => save session => worked on other non-related sessions => unmounted flash drive via workspace window to give back to client => attempted to launch session after client left => and... BAM! error message
Files exist in the audio files folder, but they appear not to have the proper audio file header/body content.
ProTools v9.0.6
HD3 Accell PCIe
Mac OS X 10.6.8
Quad 2.25 intel Mac Pro
Lots o' RAM
Any idea why this would happen?
Thanks!
Justin Davis
Rocky Mountain Recorders
  #242
Old 01-16-2012, 02:30 PM
MMAKINMITCH MMAKINMITCH is offline
Unhappy Re: "Some regions had invalid bounds and were adjusted or deleted"
It happens on my system also,I run PT 8.0.4 m-powered when I import other sessions from PT essentials(Processor : AMD Athlon 64 X2 5200+ @ 2700MHz Physical Memory :4096MB (2 x 2048 DDR2-SDRAM )Hard Disk : Western Digital WD1500HLFS-01G6U3 (150GB)Hard Disk : Western Digital WD3000BLFS-01YBU3 (300GB)
  #243
Old 08-09-2013, 01:59 PM
innerbooty innerbooty is offline
I just started getting this message in the last few days for the first time in my life. Recently I'd been having problems with corrupt audio, which I now think turns out to be due to using a 3TB eSaTa drive and PT9HD. But I'm working on a 1TB drive now and I've started getting this message occasionally. Just now I closed a VERY basic session, reopened it 10 minutes later and got this message. As far as I can tell everything is intact, but it makes me super nervous. Why would this suddenly start happening? Been working happily in PT 9HD for 4 months with no issues. (And 12 blissful, bug-free years in Pro Tools MIX3 before that...)
Any ideas...?
  #244
Old 08-13-2013, 08:42 PM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
I strongly recommend upgrading to HD10. 9 was the Vista of Pro Tools versions.
Vedat
WaveRider + Defaulter (now with LKFS)
QuietArt.co.nz
Catchin' SYNC app
Has "Some regions had invalid bounds and were adjusted or deleted" been fixed? meech Pro Tools TDM Systems (Mac) 22 06-21-2014 12:47 AM
"Out of Bounds" / "Invalid bounds" bug still exists! 12StringJ Pro Tools 10 1 07-21-2013 12:34 PM
Some Clips Had Invalid Bounds and Were Adjusted or Deleted Bug! Siegfried Meier macOS 2 01-28-2013 07:32 AM
pt8 won't open session (some regions had invalid bounds and were adjusted or deleted) terryrocks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-26-2011 11:02 AM
"Some regions invalid bounds and were adjusted or deleted" A duplicate Audio Folder ! acmost Pro Tools 9 0 11-13-2010 05:40 AM
