Audio Driver problem
i have had my Protools Mbox pro for about 3 years now, i have since installed it on 2 computers,
The problem i has happens with both computers, as soon as a start up the computer, (1st time of the day) and run protools, I get NO AUDIO at all. i even tested media files, checked my audio properties and nothing. Now if i was to record it will record the audio but i get nothing on play back, niether from protools or from the computer itself. The only way i can get this to work is each time i run pro tools, i close it down, run the cs update (whatever one) restart the computer and start over. can anyone explain this to me? im using a pc with Windows xp. on both computers. |
Re: Audio Driver problem
I had the same problem upon startup windows would steal the driver. The Mbox as the default playback for windows. In the control panel sound and audio devices/sound playback choose anything but the MBox. Another workaround is before starting PT go programs/digidesign/Divers and run the driver again each time you are about to run PT. The good new is all this was corrected in PT 8.0.3 you should update. Now I have PT as my default playback for windows and I am not experiencing these issues anymore after updating to 8.0.3.
Hmmmm, I have the same problem If I use another DAW like Reaper and then try to switch back to PT. I loose the drivers. So I can reload the drivers?
Yes you can do so; programs/digidesign/Divers and run the driver before starting PT what a pain I ended creating a driver shortcut on desktop to speed the process.
Focusrite 2.0 audio driver problem | tross405 | Pro Tools 11 | 1 | 03-13-2014 02:20 PM |
digi 003 audio driver problem | evon | Pro Tools 10 | 0 | 12-02-2013 06:30 AM |
8.04 MBox 2 Audio Driver problem | Qusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-10-2010 08:52 AM |
Audio or Driver problem? | laboya | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-16-2006 07:36 PM |
core Audio Driver 1.2 Problem | niki111 | Pro Tools TDM Systems (Mac) | 7 | 05-14-2003 12:23 AM |
