Timestretch Autmation
hi everybody, i am mixing a DVD at the mo and have to pitch the session down. change tempo and pitch like on an old tape recorder. i have already many volume automations made before i got the good news of pitching. how can i time stretch the automations when the length of the audio files is changing? or do i need to change them by hand?
thanks for help. the mixmaster |
Re: Timestretch Autmation
Can you not use the pull up/down feature in session setup?
I've never done it, but if you have a Sync I/O try the VSO option in session setup.
Do you need to change the pitch/speed of the whole session or in parts as an effect? VSO would work for the whole session.
Craig Lee@Cerny American |
the problem is audio is stretched, but the automation is not connected to that region. it is not stretching with the audio!! for me thats a big probelm at the moment.
any help is cool. |
I have used the VSO function mentioned above, and all automation follows that fine. I wanted to get the "tape slowdown" effect in one particular section, so I did it manually while printing a mix. It works fine if you are slowing/stretching. The speedup effect will only go +50cents. This worked fine for me as it was not for video. I imagine your margin for error is much smaller and sync is also an issue. When you figure it out, let us know how you did it. thanks, SB
Fx insert , preset change autmation | Shanti Monkey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 09-03-2010 06:40 AM |
MIDI Timestretch: Possible wit TCE | jem777 | Pro Tools M-Powered (Mac) | 3 | 11-20-2008 11:49 PM |
Mute Autmation | Ziptiesispro | VENUE Live Sound Systems | 2 | 04-07-2008 09:20 AM |
does PT 7.1 have timestretch? | ROCKNOID | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-28-2006 03:38 PM |
TIMESTRETCH | ahamay | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-10-2001 01:30 PM |
