What's the deal with the Digi 003 direct inputs?
I plugged a guitar to line 1 the other day and a producer told me to only use channels 5-8. He gave no other explanation except that channels 1-4 are "cursed".
I remember reading somewhere that the XLR inputs have crappy preamps and converters, but shouldn't have any effect on the TRS inputs, right?
Tampa Recording Studio |
Re: What's the deal with the Digi 003 direct inputs?
If there is a mic preamp on the input, most interfaces run the line input through a pad and then through the same preamp as the mic input. Quick and easy test: if the gain knob affects the line in, then the signal is going through the preamp.
Just checked and the gain knob affects the line in. That really sucks that I only have 4 quality channels.
I wouldn't necessarily say that. I've used the mic pres on the 002 and 003 and while they may not be up to par with a boutique class A pre, they are more than adequate for most production work.
99% of Line inputs use the same OpAmp as the Mic inputs, they just use a fixed resitor in the feedback insted of a variable resistor and all the A/D chips are the same
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
So, are lines 5-8 on the 003 the same as 1-4 but all the way turned down?
As would I. Use what works, and by all means plug your guitar into 1 and record a bit, then plug it into 5 and record a bit. If you can match the levels, I doubt you will be able to hear any difference. If you want to improve your inputs with the 003, you have several options by using the lightpipe and SPDIF inputs(which I highly recommend). For really "first class", connect an API A2D($1800) to the SPDIF input to have a pair of great preamps. Or for a bit less money, a Midas XL48($875) into the lightpipe input for 8 EXCELLENT preamps. Still too pricey? How about a Behringer ADA8200($225ish) for 8 solid preamps(designed by Midas), plus 8 more outputs(very handy for more headphone mixes). Food for thought
I definitely need to expand/upgrade my channels but do you know of anything that has 4 EXCELLENT preamps for around $500? Most of the ones I've seen are either 2 channels or 8. If I bought the XL48, could I run my Great River NV1 through it, bypassing the preamps and just use it for D/A or just keep it directly connected to the line-in on my Digi 003?
Hey albee1952. I'm a little confused here. So my SPDIF is higher quality. So plug in mic to 003 and use SPDIF out to PT?
PT 11, PT LE 6.0, DIGI 001, DIGI 003, 27" Late 2012 Intel iMac, Blue and White G3, Reason 7, Celemony, Waves, A.I.R., Softube, XLN Audio, IKmultimedia, Massey Alesis Masterlink, Alesis Adat LX20, , Yamaha Motif ES8, Sure SM58, Sure KSM27, Byerdynamic MC 834 N, Event Project Studio 6, Pod Line 6, Focusrite Trakmaster Pro DI, Glyph Drives, Lexicon, Fender Strats, Ibanez Acoustic, Ibanez Bass, Ibanez Electric. http://www.johnackermusic.com/ [email protected] Live and Let Live |
mbox3- can you direct monitor spdif inputs? | n8tron | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-11-2011 08:31 AM |
direct input monitoring of inputs 1 & 2 | luidog | Digidesign Hardware & Software | 0 | 09-23-2009 08:59 AM |
no digi 003 yet.....what's the deal with M-Audio? | audio53 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-21-2007 12:20 AM |
DIGI, Come On...What's the deal 4 EXISTING HD SYS? | Ginger | Pro Tools TDM Systems (Mac) | 41 | 10-29-2005 03:42 PM |
What's the deal here Digi?!?! | leftalive | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-27-2004 02:16 PM |
