Help!! Can't get Avid Artist Mix to work
I'm helpless...
There is absolutely no chance to get my Avid Artist Mix running ... Network errors all the way. I un-reinstalled Eucon and Pro Tools - no change. EU Control does not recognize the Artist controller. Tried all power up possibilities, both of the ethernet connectors on the MacPro, several different cables. I had one moment when the artist mix was properly recognized after booting and showed up in the EuControl setup window but as soon as I launched Pro Tools the "Unable to connect" window pops up prompting me to check cable connections and power off the unit for 30secs which does not help and only will result in the same error message after re-boot. The setup was working without any problems for 4 Months until last week. At that point I decided to update to 10.3.4 and EuControl 2.7 but experienced problems with the touch sensitivity on the faders and downgraded back to PT 10.2 and EuControl 2.6.2. From this point on the Artist Mix unit is no longer properly recognized. It does appear in the "all surfaces" window and can be added to the "my surfaces" window but when I start Pro tools the "Network error - unable to connect" dialogue appears. I could really need help with this!!! Please post solutions (: My setup (ProTools 10.2 - also tried 10.3.4, Eucon 2.6.2 - also tried 2.7 no change to the better) running on a Mac Pro 5,1 24GB RAM, OSX 10.6.8 |
Re: Help!! Can't get Avid Artist Mix to work
Have you made sure the Mac is set to DHCP? Also, is the Mac part of a network? Have you tried setting the Mac and the Mix to static addresses?
Mac Pro 6.1, E5-2690 V2 10 core 3.0G, 32gig 1866 memory, 512G PCIe system drive, 4 480G OWC 3G SSD data drives in Thunderbolt 2 enclosure, macOS 10.15.7, Pro Tools Ultimate 2020.9.1, Twin Raven MTi's, Apollo 8 TB, 2 UAD2 Satellite Octo Thunderbolt, RME ADI-4 DD, Neve 5012, 5043, Bricasti M7, 2 PCM 92's, M350, DynAudio BM6 MK 3, BM14S, a bunch of cool mics...1 damned iLok2. |
Thanks for the tips ArKay99,
I just installed EuControl 2.7.1 and this seems to have solved the problem. I was just about to set up static adresses but will wait how things turn out now. Are there any disadvantages when setting Mac and Mix to static adresses or why is not the standard routine?
MacMini 8,1/ 32GB Ram/ OSX10.15.7/ ProTools Ultimate 2022.10 + 2021.12/ Focusrite Red4Pre/ BM Decklink Studio 2/ Avid S3 |
Thanks again for the prompt response!
I will backup my system drive and try to install PT 10.3.4... That was the original attempt to touch the current setting... I will report either success or disaster
If you are Directly connected to your Mac (no switch or Router) there is a known issue on first connect. The error message sends you down the wrong path leading you in a circle.
Simply go to EuControl and it should appear in All Surfaces. Select it and add it manually. Also setting static iPs on the NIC and the Surface does make startup time faster for EuControl because it does not have to wait for the NIC to resolve to link-local address. |
Avid Artist Mix - only ports 1-4 work, I've tried everything! | joren | Artist Series | 5 | 05-28-2014 03:10 PM |
FS: Avid Artist Mix | Chingy | Buy & Sell | 1 | 02-19-2014 07:49 AM |
AVID Comes through on my Artist Mix | ArKay99 | Artist Series | 2 | 02-03-2013 02:52 PM |
FS: Avid Artist Mix | jeffinaustin | Buy & Sell | 1 | 06-25-2012 09:19 PM |
The studio I work for just bought an avid Artist combo | zblip2 | Pro Tools 9 | 5 | 02-22-2012 08:19 AM |
