Old 11-12-2019, 01:13 PM
JFreak JFreak is online now
Default Re: Replace Clip Issue
Slate Trigger is 10.6 or later and I know for a fact that it works with PT10 -- if the most recent installer doesn't work with 10.6.8 just ask their support to send you one that does.
Old 11-12-2019, 01:28 PM
groovebrother groovebrother is offline
i obviously missread something when i visited the website ... or mabe i was in the wrong one as i saw only 10.9 & above for compato.
Sorry
I also could see a gearslutz topic where they say we can import our own samples as it reads wav files.
I just hope it does read 88,2 & 96 k... i'll investigate
thank you JFreak for insisting !!
My soundcloud page
Mac Pro 2x 2.66GHz 6-Core / 96 Go Ram / PE6R4-i - HD Native - Tempo Sata Pro 6Gb - PTHD : 10 / 11 /12 / Ultimate till 2022.5 - 192 i/o Digidesign - MTPAV - OSX : 10.4 / 10.5 / 10.6.8 / 10.8.5 / 10.9.5 / 10.11.6 / 10.13.6 / 10.14.6 - PowerMac G4 MDD / Pro Tools HD 5.3 / 6 / 7.4x / 8
Old 11-12-2019, 01:37 PM
No problem.
Though I have no idea how well it suits you, the people that I know using it are mixing heavier stuff.
Old 11-12-2019, 09:56 PM
cwsand's Avatar
cwsand cwsand is offline
Originally Posted by groovebrother View Post
As i said i adjust the volume manually using clip gain after having replaced all instances.
Wow that seems like a pain too. I actually use an ancient program called Beat Quantizer that will replace clips with new samples at a matched volume - though it can be tedious too. I've had varying amounts of success using Drumagog and Melodyne but I always have to make adjusments with them. I've heard nothing but good things about Slate Trigger - I'll have to try it!
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (3)
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 11-13-2019, 05:45 AM
thank you Chris
i think there might be a solution as i am in touch with a certified avid guy in France that just wrote me it's working with his station.
I'll keep you posted.
And again, i have done it once so - i must find out why i cannot do this again... just to free my mind
My soundcloud page
Old 11-13-2019, 08:09 AM
Default Replace Clip Issue (SOLVED)
Dear colleagues of the DUC ...
It's done !!!!
but under 10.8.5
I gues my 10.6.8 must have been altered somehow and i guess a clean install is to planify
What i did was : select all clips & rename all of them (rename automaticly fonction in the clip listing)
Pop Up Window (After shift+cmd+drag) & selected
- "Replace..." : "all clips corresponding to original clip"
- "On... " : that track
- "Adjust clip..." : Original clip's lenth
But i also tried with consolideting the original track, used Strip Silence and did that same operation & it worked fine too with "auto rename clips" selected in the prefs menu.
The point is that the French colleague told me that in the prefs menu, the "clip list selection follows edition selection" had to be unselected.
I found out it was not necessary.
DONE !!!
ahah ah i feel so good now ...
Again thank you all for your time & wish you a happy & groovy day !!
Dominique
Now the greatest thing would be pro tools to analyse each velocity and replace clips with a new one matching original velocity
My soundcloud page
Old 11-13-2019, 08:31 AM
Good to hear
Old 11-17-2019, 05:35 AM
Default Re: Replace Clip Issue (SOLVED)
hey guys, i've done it again on another session ...
Yep if the song exceed 5 minutes or/with many many clip gain adjustments to do.
But that's okay as long as it serves the music and/or cannot do another recording with the drummer or (cuz that might happen), he just has a dreadful kick drum, or the mic choice & position has just messed up the drum take. That is the case with that album i have to mix for now
My soundcloud page
Old 11-17-2019, 10:33 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Avid Audiosuite “SoundReplacer”
3 samples/files
3 trigger thresholds
Old 11-17-2019, 11:14 AM
3 samples/files
good god ... this one does exist for quite a time ? right ? i completely forgot about it !
I must say that i am not used to replace stuff in recorded audio
My soundcloud page
REPLACE CLIP option greyed out EricWillhelm macOS 0 02-14-2018 07:05 AM
Replace clip in 11HD is greyed out bcslaam Pro Tools 11 3 02-14-2018 06:58 AM
replace clip pinnacle Pro Tools 10 7 08-05-2013 01:45 PM
Replace clip error-bug? Ramtitam macOS 2 08-05-2013 02:11 AM
