Old 03-31-2019, 01:26 PM
ProtoolsLover ProtoolsLover is offline
Default XMON - Just Not Happy With It
I’m running a 24 channel D command, and I’m curious if any of you have stopped using your XMON for monitoring and gone with an alternative unit.
If I did replace it with something else, it would be in the sub $1000 range.
I have good monitors, Adam Audio A77X’s, There just seems to be an unpleasant harshness coming from them regardless which source I choose from the D-command. It’s not a significant harshness, but just doesn’t seem right.
When I tried to calibrate the various inputs going into the XMON, it doesn’t seem to be registering any difference on the meters on the D-command. My ProTools send to the XMON is my Omni, levels for it seem balance between left and right. The others three, on the meters show the left side hotter than the right.
Input one is audio coming from my computer. Input 2 is from my Kemper, input three is from a Bluetooth Receiver.
So after all of this, I guess I’m asking two different questions here.
One if there something I’m doing wrong with calibrating my XMON? I read the manual 10 times, and I seem to be doing it right compared to the manual.
Second question, there seem to of been a lot of advancement in sub $1000 monitor controllers, since the XMON came out, even if I weren’t having the issues mentioned above, would any of you recommend me changing to one of those? Some examples below.
Drawmer MC3.1 Active Monitor Controller
https://www.sweetwater.com/store/det...tor-controller
Dangerous Music SOURCE
https://www.sweetwater.com/store/det...s-music-source
Heritage Audio RAM System 2000 Desktop Monitoring System with Bluetooth
https://www.sweetwater.com/store/det...with-bluetooth
Coleman Audio CMC4 Monitor Controller
$1,200
Coleman Audio M3PHMKIII - Monitor Controller
Old 04-02-2019, 06:14 AM
andrej770 andrej770 is offline
Default Re: XMON - Just Not Happy With It
I have a D-Control, but I guess I'm asking whats not to like about the XMON? Its sole purpose is to give you simple monitoring of audio. Its not meant to be a mixer or amp or to allow for extra bangs and whistles or even special routing (unless you are using the software); its just a monitor. Further it gives you full control of it from the control surface. I don't know of any other solutions that actually connect to the D-Control/D-Command, that use the controls on the control surface, yet do more than what the buttons on the control surface allow. What exactly are you wanting? Personally it sounds to me like you may be outgrowing your D-command and it may be time to move to a used D-Control or newer board.
Mac 8 Core 6,1 - OSX 10.13.6 - 32GB RAM - Pro Tools 2018.10 - 8x8x8+8 ch DA Card (x2) - HD OMNI - ICON D-Control 32 - Sync I/O - Sonnet xMac Pro Server w/HDX x 1, Blackmagic Intensity Pro 4K
Protools 2018.10 HD Native in 1 project suite
Eristopher Music
7.1 and XMon? subwoof Post - Surround - Video 5 08-14-2017 06:43 AM
Fs: Xmon Serge Perron Buy & Sell 3 07-16-2017 11:58 AM
Old XMon on S6? paulo m Pro Tools | S6 15 08-20-2014 03:22 AM
looking for a Xmon francois Buy & Sell 3 12-05-2013 05:24 PM
XMON tstemland ICON & C|24 2 03-23-2006 02:00 PM
