Old 03-21-2016, 09:38 AM
wwerwath wwerwath is offline
Default Dyn button disabled
Hey There
I'm sure I'm just missing something obvious, but for some reason in my session all of the dyn buttons next to the tracks are disabled and none of the tracks are reading any automation. Anyone know how this can be fixed? It's driving me crazy.
Thanks
Will
Old 03-21-2016, 09:47 AM
Default Re: Dyn button disabled
Ok also just noticed I can't switch the tracks to input monitoring.
Old 03-29-2016, 01:36 PM
I'm going to bump this because it just happened in another session and I'm going crazy. Now it has only disabled automation on my instrument tracks. Again, the dyn button is disabled and all the automation is not working and is greyed out when I select it. Anyone had this happen? I'm sure it's some new mode or something with pt 12.4 but I can't figure out what.
Old 03-29-2016, 09:05 PM
soybalm soybalm is offline
Make sure they are assigned to non italicized outputs.
Dave Cournoyer-guitarist-project studio
Mac Mini late 2012, i7, Sierra
16GB PT10.3.10HD PT12.5.2
Apogee Mini-Me firewire.
Old 05-10-2018, 04:04 PM
Audiofeeling Audiofeeling is offline
I have the same problem!!! nice that finally i found a post where this topic is debated.
I have just registered here to comment .
To me, it doesnt happen in all the sessions. Just in some, random.
The first time it happened to me, it was a session sent to me, to mix. It only was happening in my most powefull computer: my hackintosh, if i opened the same session in an older mac pro 3.1 i didnt have that problem.
I have been one year without this problem and now it happened again!
its a session that i recorded and i created from 0. I made a save copy in to have a clearer and lighter session in order to mix without other playlists and many discarded tracks.
Its a mix that its taking more time than the usual (i am also the producer). the First day working on it, no problem at all, i did Some renders, changes...
i use to make "save as", from some steps to others,
well, second day this issue started. if i open an older session, or some backup session from yesterday, or from 5 hours ago, there's no problem, but , with my current session (the one with the last changes) its takin about 20 minutes or half and hour to open (with this circle icon in the mouse showing that its working) it looks like a pro tools crush but it you wait, it reborn. All the time with the "dyn" option in blue.
yesterday i fixed it opening and old backup without the problem and making import session data with all the tracks, matching tracks. But it doesnt work all the times.
If i wait untill the session opens (20/30 min) i can work, but next time i reboot pro tools, it will take as long as i said. 20/30 min.
Sorry for my english i do my best.
I dont know the reason, it cant be the RAM, or other issues you have already mentioned.
Thank you in advance for your help
Old 05-10-2018, 04:40 PM
hey guys, the trick of opening the session with all the plugins unactive, (holding shift while double click on the session) it works, it must be a plugins issue.
i suspect it could be amplitube, do you guys, had amplitube in that sessions?
Old 01-09-2019, 08:33 PM
davidskick davidskick is offline
I have the exact same issue. I have PLENTY OF RAM (64G) and using a super powerful mac trash can.. with PT 2018.12.0 I have an Avid support case open. They don't have a clue of what's going on... Anyone??
Mac Pro Desktop Quad Core w/64G of DDR3 ECC memory & Sonet Expansion Chasis for PT 2018.12.0 HDX Card in conjunction with Burl Mothership & converters - C24 Console
Old 01-10-2019, 05:01 AM
I've had the issue with two IKMM plugins - Amplitube and Sampletank. In my case the sessions had early versions of both plugs and now having the newer versions the old sessions barf.
Have you tried opening the session in safe mode?
Any third party plugins in the session? If so open in safe mode and then one-by-one re-enable a plugin. Save the session, quit PT and reopen the session. Restart the session and if it works okay you've found the problem plugin. If not just repeat the process.
What OSX are you running?
Jack
QAPLA!
Eleven rack sound while record button disabled brad383music Eleven Rack 8 04-17-2014 10:15 AM
Preamp phase invert button enabled or disabled during recording vocals with Omni ? chrisdee Pro Tools HDX & HD Native Systems (Win) 0 11-26-2012 07:01 AM
Multi Button editing disabled JohnFH Pro Tools 9 1 08-25-2011 05:54 AM
Record Enable button gets disabled... gilorlev 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-29-2010 11:35 PM
done button replaced with open button. ronoc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-24-2009 11:20 AM
