Old 07-27-2006, 08:39 PM
twixer twixer is offline
Default Large audio files being created
Hi all. I had an issue on a system i was working on. I was using quickpunch on an HD|2 system and it kept creating these large files. They would be the same size everytime like 1.98gig files. They weren't audio files i was using either. The thing that sux the worst was it would lock up the system when it created one of the files. Any clues.?
thanks
adam
Old 07-27-2006, 08:42 PM
Default Re: Large audio files being created
Go to Setups-->Preferences-->Operation, and on the right hand side, set open ended record allocation to a number (I use 70 minutes) instead of use all available disk space.
Old 07-27-2006, 11:36 PM
crizdee's Avatar
crizdee crizdee is offline
thanks
adam
Just remember that in quick punch, you are recording as soon as you start the transport, only the region from when you punched in and out will then show in the track, but the whole complete file is also recorded and kept! this file will be from when you started playback till when you punched out or stopped the transport.
Chris
Producer, Engineer,
www.ukmastering.com
Audio Files Folder..Not Created?. pguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-07-2008 09:02 PM
no "renamed audio files" folder is being created tomcat Pro Tools TDM Systems (Mac) 12 06-18-2006 10:29 PM
no renamed audio files folder being created tomcat Post - Surround - Video 0 06-05-2006 08:13 AM
no audio files being created laozi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-26-2005 04:33 PM
Huge audio files created on crash!?!? Anibal Pro Tools TDM Systems (Mac) 2 04-19-2001 08:19 AM
