Old 08-07-2009, 01:23 PM
nburbank nburbank is offline
Default What can you undo?
Does anybody know of a list of what actions you can and cannot undo?
thanks
Old 08-07-2009, 01:25 PM
Default Re: What can you undo?
You can undo almost everything.. but certain actions like select all unused regions clears the undo buffer.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 08-07-2009, 01:26 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Pretty much all is undoable if u did it... Only suck part is u can't go back & undo a certain thing after u already passed it without undoing what u did afterwards(U may have to read that a few times to get it-almost confused me & I wrote)
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 08-07-2009, 02:20 PM
drenkrom drenkrom is offline
Off the top of my head, most of the things you can't undo relate to tracks themselves. Creating new tracks, changing i/o assignments, inserting plugs, moving tracks in the edit window all can't be undone, for example. I think all region-related operations are undoable.
Old 08-07-2009, 02:23 PM
c-tone c-tone is offline
There are a lot of different things in PT that are not undo-able, unfortunately, and I wish they would change that.
here are a few:
1) Removing a plug-in
2) changing most plug-in parameters
3) changing automation mode (which can in turn change settings such as levels)
4) changing input, output, and send assignments
5) Showing/hiding tracks
6) Split stereo track into mono (also clears undo cue)
7) Deleting groups (although it warns you that is it not undo-able)
These are just a few that have caused problems for me. They might look like they would be easily undone with one step, but under certain circumstances, these can cause all kinds of unintended consequences, and the only practical solution is to close the session and load the latest auto backup.
Again, like Keybeeetsss suggested, what we need is for every action to be undo-able, with a true selectable undo list, where you don't have to undo everything that you did after the one thing you want to undo.
www.clifnorrell.com
Old 08-07-2009, 02:59 PM
T-Low T-Low is offline
+++1
ALT+click on a fader by accident
with All or a group selected ...
Old 08-07-2009, 04:24 PM
Andre Knecht Andre Knecht is offline
Originally Posted by T-Low View Post
+++1
Actually, that last one is undoable, provided “Include Control Changes in Undo Queue” is enabled in the PT Preferences (Mixing).
IHTH.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 08-07-2009, 04:28 PM
IHTH.
i´ll check it out tomorrow
thanks Andre
Old 08-07-2009, 04:33 PM
hmm... it´s marked in my prefs , but i can´t undo this ... ?
Old 08-07-2009, 04:56 PM
Oroz Oroz is offline
You can add "delete tracks" to that. Other programs can undo the deleted tracks.
Mic Pre Undo kimlau ICON & C|24 0 01-10-2009 07:21 PM
Undo in 7.2 Muzoid Pro Tools TDM Systems (Mac) 21 09-07-2006 04:49 PM
keep the fader UNDO and edits UNDO separate uno1234 Pro Tools TDM Systems (Mac) 5 12-06-2005 09:30 AM
I can't undo record audio, I CANT UNDO !!! Dither16bit Digidesign Hardware & Software 0 06-09-2004 01:53 AM
undo realnitepeople MIDI 1 08-21-2003 01:29 PM
