Drawing waveform underneath a fade
When I was using Pro Tools 8 up to 10, I used to be able to edit the waveform underneath a fade in/out using the pencil tool. All I had to do was zoom in to the maximum zoom and the pencil would no longer be greyed out and I could make waveform adjustments.
Since version 11, I've been unable to do this and found no way within preferences to enable it. I've also had no luck with online searches. Anyone know if/how this is possible? Cheers! |
Re: Drawing waveform underneath a fade
Fades are no longer rendered (I believe that went away in PT11), so to redraw the waveform under the fade you'll need to either remove the fade, redraw, then reapply the fade, or select the fade area and consolidate (shift-opt-3) and then redraw.
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
Ah well that'll explain it, what a pity. Thanks for letting me know.
I believe this works because drawing is destructive.
Drag the same clip/file that you have the fade on to a different track, fix it there. It should fix the clip with the fade on it too since they are the same file referenced and the fade is not rendered but played back in real time.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
That's a good idea - I wonder if PT will require re-caching the audio to play back correctly on the desired track? In the past I've had mixed luck with this sort of thing, and had to close and reopen or change my cache settings to get it to work...
Problem drawing waveform | Mack Truck | Pro Tools 10 | 2 | 07-23-2012 05:41 AM |
Waveform drawing | Boe Larsen | Pro Tools TDM Systems (Mac) | 2 | 01-18-2012 07:53 AM |
Waveform drawing fix for 7.4???? | Kmajorkminor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-01-2008 10:16 AM |
Waveform Drawing Issue??? | Enkonis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-17-2008 03:13 PM |
Waveform Drawing Question | CFS | Tips & Tricks | 17 | 10-04-2001 01:15 AM |
