Old 01-25-2011, 09:32 AM
nexty76 nexty76 is offline
Default Gain Levels
Just bought MAudio BX5A's to use with my Mac MBox mini PT8 setup. When looking to listen to iTunes library, I have the monitors hooked into my headphone jack. Is there a better way? As far as gain levels go should I have the speaker volume at 50% and keep the itunes/mac leves high or vice versa? Does it make a big impact on the sound quality? Any help is much appreciated!
Old 01-25-2011, 09:44 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: Gain Levels
You don't want to feed a hot signal to your speakers. That may distort the input. On the other hand, you don't want a weak signal that may add noise when you turn up the volume on your speakers.
You should be using the monitor outs to feed the speakers. You may have a mismatch that can affect frequency response by using the headphone out.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 01-25-2011, 09:50 AM
Is there a way to have itunes played thru the mBox mini? When I go into System Preferences/Sound and select the MBox, it says: Device does not have output controls.
Old 01-25-2011, 09:55 AM
barstool719 barstool719 is offline
its referring to internal software volume control (the little fader in windows)... your mbox has a level control.
i7-860 / 12GB Kingston / Intel DP55WB / 500GB Barracuda / 1TB Deskstar W7x64
Focusrite Saffire Pro 40 / Pro Tools 9.0.3
Mics, Guitars, Amps, Basses, Drums, Keys
http://overtheeffect.bandcamp.com
Old 01-25-2011, 01:56 PM
So what is my fix, how do I get my Mac to recognize the MBox as my output device?
Old 01-25-2011, 03:45 PM
tom1325 tom1325 is offline
go to Utilites, Audio MIDI Setup, select mbox from there and configure speakers to whatever output your using.
Old 01-27-2011, 05:26 AM
When I go into the Miidi Setup, I don't see an option to add the MBox. I though this would be a relatively easy task, assuming that most people use the MBox for iTunes playback? Might try the Avid helpline, which I'm sure will cost me a bit. I tried apple and suggested reinstalling Pro Tools, since when I got to System Preferences-Sound: If I select the MBox2 Mini under settings it says 'Selected device has no output controls' Any suggestions? Thanks again.
A Question on Gain Levels - Too Hot or Not PC Nemesis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-10-2005 02:29 PM
Microphone levels too low - need more gain gagard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-19-2004 10:01 PM
Gain Levels...recording StainedClass Pro Tools TDM Systems (Mac) 65 03-28-2003 09:11 AM
Mastering and gain levels surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-21-2002 12:29 AM
GAIN LEVELS on mics marilyn manson and the spooky kids 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 03-01-2002 12:07 AM
