Old 05-21-2011, 05:08 PM
Jermak Jermak is offline
Default Re-Amping (What to use?)
This is not a question of how to do re-amping but what to use.
The guitar input, for most of us, is through the front guitar input and is mono
and this is where the dry signal is taken from.
The wet signal further along the chain can be mono or stereo.
I was wondering how people record and re-amp these signals and why.
For instance, my method and reason (as the how-to has been explained in print and video).
I use the SPDIF into 003 to record mono DRY and mono WET. Works ok but I thought what if I want stereo effects (like panning ) so I then connected the Main-outs (XLR) this gives me the stereo. This input also gives me a very good guide on the record meters in PT of signal strength. I set the WET output of the rigs to show the top third of the yellow area in the meters when hit the hardest.
So I now use the XLR to record WET and mono SPDIF to record DRY. This raises the question should I record SPDIF in Stereo for ease of use, but then ask myself why because the input was mono anyway.
Win7x64
PT 9.0.5 DIGI003 Digimax FS
ASUS P5E Q6600 6GB
Eleven Rack + EXRP
Old 05-21-2011, 05:23 PM
The Dougfather The Dougfather is offline
Default
You re-amp a signal if you want a different sound. Let's say you tracked with a Marshall and later decided you wanted a Mesa sound. You could re-amp to the Mesa using the dry signal, radial make a re-amping unit.
Not sure I understand the fx thing but a lot of sources use stereo effects on mono sources, guitar, vocals etc. Most effect units allow you to input mono and output stereo.
Sent from my iPod touch using Tapatalk
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 05-21-2011, 10:55 PM
Default Re: Re-Amping (What to use?)
Thanks Dougfather (great name ) but I understand Re-amping both how to do it (i do it ok) and why one does it. What I obviously didn't make clear (sorry about that) is do you use SPDIF and do everything digitally and is that 1 dry and 1 wet or XLR out for the same thing but using digital to analog.
The fx thing you didn't get was that if the wet output has fx's that use the stereo spectrum (like auto panning or stereo delay) then that is useless if the wet output is mono.
Win7x64
ASUS P5E Q6600 6GB
Eleven Rack + EXRP
Old 05-22-2011, 11:25 AM
brianiac5150 brianiac5150 is offline
Check out Benoni's vid: http://www.youtube.com/user/BenoniSt...19/eWP0EIFz0c0 for some guidance when when using the S/PDIF.
THoM Facebook
Re- amping music Tips & Tricks 11 09-01-2013 01:19 PM
hum during re-amping mblackman Eleven Rack 5 09-03-2012 01:17 PM
Re-Amping with PT9 Platereverb Eleven Rack 2 05-28-2011 05:53 AM
Re-Amping with 192 I/O ericsvizeny Pro Tools TDM Systems (Mac) 22 04-18-2011 08:47 AM
DI for re-amping? syra Pro Tools TDM Systems (Mac) 5 04-02-2003 10:23 PM
