Re: 8.1.1 Invalid digital signature for drivers
Been using Pro Tools HD 8.1 with windows 7......in XP mode!!!rightclick on the icon and run Pro Tools that way,nooo problems whatso ever.
https://scontent-b-dfw.xx.fbcdn.net/..._3222165_n.jpg |
8.0 + always ran great in windows 7. But once you go to 8.1.1 the drivers for the HD hardware will be rejected by the OS...nothing to do with PT itself.
ProTools 2018 1 x Apollo Quad Firewire 1 x Apogee Duet 2 mac/ios MacBook Pro (15-inch,2018) 2.9 Ghz Intel Core i9 CPU 32 GB 2400 DDR4 RAM 1TB SSD System Drive Mac OS High Sierra 10.13.6 |
I know what you mean, but in the end effect it is not so funny, if you have to spend hours for something that should be fixed by the ones who said: “Although not officially supported, Pro Tools HD 8.1-8.1.1 can be used on Windows 7 (32 and 64-bit). No additional drivers are required for HD systems.“
And it's not difficult to fix this - they just need to sign that driver! However, since my last post I am running v8.1.1 with v8.1 drivers and did not recognize any problems! I did many things the last weeks: recording, mixing till my HD2 Accel reached 100% system load and also used structure free. (Somewhere I read about problems with these creative suite plugins) I don’t want to run my windows all the time in this test-mode. When you are in there installing some software, every driver can be installed without notice and this may cause other problems in windows. This mode is for software/driver development and should not be used in a professional working environment. That’s just my opinion about this. Trying v9 drivers would be interesting but I didn’t find any download. If you have a link I would download it and try if there appear issues with my current setup v8.1 drivers. But I think and hope that there are no problems using v8.1 drivers. That’s what I recommend to all the ones who have the same problem using Windows 7 x64. Best regards |
http://mrbigear.com/
should be dropped!
#16
#17
You’re welcome.
By the way, I see from your signature that you have software version 9.0.1. Why do you need this then? |
#18
I have multiple systems and a few studio locations. My main rig is actually 10, but I have 9 on the other and finally still using 8 on this particular setup. Ran a 6 hour full band session last night and was rock solid.
thanks!
#19
I just want to add the following here:
If you want to use Ethernet DAW-Controllers using the Digidesign Ethernet Support protocol you have to install the same version of this protocol as your running Pro Tools is. So if you are running Pro Tools v8.1.1 with v8.1 Audio Drivers you have to use v8.1.1 of Digidesign Ethernet Support (install during Pro Tools 8.1.1 Update) |
#20
technique to install PTHD 8.1.1 on win 7 (PCI cards: core + 2 accel)
install HD card hardware, boot computer Install 8.0 from the original CD Follow directions as to when to connect or disconnect digi-cables to cards reboot as indicated. Close Protools Update to 8.05 Find C:/Program Files (x86)/Digidesign/Drivers Right click on 'Drivers' folder and Copy and then . . . Paste whole 'Drivers' folder onto Desktop Find C:/Program Files (x86)/Digidesign/Drivers Right click on 'Drivers' folder and Copy and then . . . Paste whole 'Drivers' folder onto Desktop Update to 8.1.1 following directions reboot as indicated Open C:/Program Files (x86)/Digidesign/Drivers rename MMRrefresh.exe to MMRrefreshbak.exebak Delete all files in "C:/Program Files (x86)/Digidesign/Drivers" but don't delete the Folder Open the Drivers folder that was placed onto the Desktop earlier Lass everything in the driver file (the 3 subfolders and the MMERREFRESH.EXE file) and COPY OPen C:/Program Files (x86)/Digidesign/Drivers, and paste the folders and files you just copied into the C:/Program Files (x86)/Digidesign/Drivers Reboot the computer Open My computer, and go to system properties at the top, system devices, and then into device manager. Under unknown devices you should find a long list of Mediacontrollers and 2 PCI bridges, each of which should have the yellow problem icons. Right click the top problem icon in the list, and choose update driver. You will then manually direct the computer to the location to where the drivers are. Choose C:/Program Files (x86)/Digidesign/Drivers This will then install the first driver, and that line will dissapear; reappearing now under the Sound video and game controllers section of the devices. Do the same for each remaining problem icon, line after line. You now should have a fully operational installation of 8.1.1 running on Windows 7. Remember also that you may need to update certain options (like mp3 option) and certain plugins that can be found on the Avid site under 8.1. downloads. I am currently working on getting the Creative Collections working. But for now everything appears to be working within the known issues of 8.1.1 If you need, please feel free to give me a shout at [email protected] Regards, Mark |
Signature? | lkmuller | Getting Started | 1 | 10-31-2013 11:59 PM |
DUC signature | jre3132 | General Discussion | 3 | 03-02-2007 06:03 PM |
Where can I add a signature to my posts? | Hollens Studios | General Discussion | 3 | 01-20-2006 01:45 PM |
OT !! who has the coolest signature ? | lemix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 19 | 11-07-2004 09:24 AM |
192 Digital I/O... Coreaudio drivers limited? | mistermarr | Pro Tools TDM Systems (Mac) | 1 | 11-11-2003 12:30 AM |
