Old 09-14-2012, 02:23 AM
pinnacle pinnacle is offline
Default punch in loop pre roll
Hi, Im trying to do a punch in/out part of vocal track but I want to do it on loop so I can do a few takes at once. However after the first take the playhead ignores the pre roll flag. Is there a way to set so that It will loop continuously back to the pre roll? thanks
Old 09-14-2012, 02:56 AM
Stig Eliassen's Avatar
Default Re: punch in loop pre roll
Not that I know of. I would turn off pre-roll, and just extend the selection to match.
Old 09-14-2012, 03:13 AM
Thanks for your reply :) I would but then Ill record over the other parts.
Old 09-14-2012, 03:52 AM
Yes, but you can trim the clips after you're done recording. I usually record to a new track.
Old 09-14-2012, 03:19 PM
jasonthurley's Avatar
jasonthurley jasonthurley is offline
Or you could simply make a new track to punch in on and cut the part you are replacing out of the existing track... That way you never record over anything and once you have the right take edited can slip it into place.
Punch-in with pre-roll on LE 8 johnmclainVO 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-05-2011 12:42 PM
I Can't get Pre-Roll to work when trying to punch in oncepureband Tips & Tricks 4 05-13-2011 01:40 AM
Simple question PUNCH in with a PRE ROLL Seltaeb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-29-2010 12:11 PM
Punch Ins/Pre Roll help Sonic Blue Meanie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 03-27-2010 12:53 AM
Pre-roll punch in not working in PT 8 LE Guitarboy Rocks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-20-2009 01:54 PM
