Can not launch PT LE 7.4! Crashes when SETTING UP MIDI
Hi;
I had been using PT LE 7.3.1 cs5 until today without any problem. Today, I've downloaded the PT LE version 7.4 and installed it with no error messages and tried to launch it. But everytime I get the same warning when launching, ( it is written "setting up MIDI" on display when error occurs ) and Windows terminated the ProTools application immediately. I couldn't write down the authorization code still Now I've turned back to PT LE 7.3.1 cs5 again. I've uninstalled and deleted everything before installation of 7.4. The latest version of Inter Lok driver is installed too. WHAT MUST I DO??? Dell Inspiron 6000 laptop, Windows xp sp2, 1.73 GHz centrino, 2 Gb RAM, Mbox2 USB audio interface with updated firmware 1,43. Ogun. PS: My computer and PT LE 7.3 were working together successfully. Here is the error report: AppName: protoolsle.exe AppVer: 7.4.0.309 ModName: msvcr80.dll ModVer: 8.0.50727.762 Offset: 0004686a |
Re: Can not launch PT LE 7.4! Crashes when SETTING UP MIDI
Try this:
See if that helps.
Hi Marwaq;
Thank u for your reply. I've read the articles. And tried to re-install again and again. But I'm still having trouble in terms of launching PT LE 7.4. And the advice on digidesign's offical site didn't work! I think PT LE shouldn't be available until it has passed the tests. I'm using the Turkish version of Windows XP. But IT SHOULD NOT BE THE PROBLEM!!! There are great features in 7.4, I paid for these great features, and now, I am STILL USING the OLD VERSION. Pay for 7.4 but use 7.3.1 cs5! I hope Digidesign Techs read these... Have a nice day Marwaq... Ogun. Owner: Ogün Organisation: Jingleman User: Ogün Operating System: Microsoft Windows XP Home Edition 5.01.2600 Service Pack 2 Report Date: Perşembe 15 Kasım 2007 at 21:12 ------------------------------------------------------------------------------------------ <<< Mainboard >>> > Manufacturer : Dell Inc. >> General Information Product : Inspiron 6000 Version : Unspecified Serial Number : 51LGW1J Unique ID : 44454C4C-3100104C-8047B5C0-4F57314A SKU : Unspecified Family : Unspecified Start mode : Power Switch >> OEM Information OEM #1 : Dell System OEM #2 : 5[0003] OEM #3 : 13[PP12L] > Mainboard : Dell 0W9260 >> General Information Manufacturer : Dell Inc. (Dell) Product : 0W9260 Version : Unspecified Serial Number : .51LGW1J.CN129615996333. Support MP : No >> Chassis Information Manufacturer : Dell Inc. Type : Notebook Version : Unspecified Serial Number : 51LGW1J Asset : Unspecified >> On-Board Device Information Device : Intel 915GM Graphics (Video) Device : Sigmatel 9751 (Sound) Embedded Controller : No >> Slots Information Slot PC Card (PCMCIA) : Available (32-bit) 5.0v, 3.3v, PC Card-16, Cardbus, Zoom Video, Modem Ring Resume >> External Connectors USB : Access Bus (USB) Video : DB-15 female FireWire (IEEE P1394) : 1394 Modem : RJ-11 Network : RJ-45 >> Internal Connectors USB MONITOR FireWire Modem Ethernet > Bios : Dell Inc. >> General Information Manufacturer : Dell Inc. Version : A09 Date : 28 Eylül 2005 Address : 0xF000 on (byte=) KB Copyright : Copyright (C) 1985-1988 Phoenix Technologies Ltd. DMI Version : 2.3 >> Characteristics Flashable : Yes Socketed : No >> Functionality APM : No ACPI : Yes ESCD : No PnP : Yes PCI : Yes ISA : Yes AGP : Yes USB : Yes PCMCIA : Yes Smart Battery : Yes >> Boot Information Selectable Boot : Yes CD-ROM Boot : Yes PC Card (PCMCIA) Boot : No I20 Boot : No LS-120 Boot : No 1394 Boot : No ATAPI ZIP Boot : No Network Boot : Yes > Chipset : Intel i910GML/i915GMS >> General Information NorthBridge : Intel i910GML/i915GMS SouthBridge : 82801FBM (ICH6M) LPC Interface Bridge >> NorthBridge Information Architecture : Direct Media Interface (DMI) Manufacturer : Intel (Dell Computer Corp) Codename : Alviso Revision : B1 Bus Speed : 133 MHz FSB Frequency : 532 MHz (QDR) FSB max. Support : 533 MHz RAM max. Support : DDR2 (533 MHz) >> Memory Information Type : DDR2-SDRAM PC2-4300 Frequency : 266 MHz DRAM/FSB Ratio : 2/1 Supported Channels : Dual (128-bit) Activated Channels : Dual ECC Diagnostic : Hayır CAS Latency (tCL) : 4 clocks RAS to CAS (tRCD) : 4 clocks RAS Precharge (tRP) : 4 clocks Cycle Time (tRAS) : 12 clocks Shared Memory (video) : Yes >> Video Information Integrated Controller : Yes Enabled : Yes >> Device Capabilities (PCI) I/O Access : No Memory Access : Yes Bus Master Capable : Yes Special Cycle Recognition : No Memory Write & Invalidate : No VGA Palette Snoop : No Parity Error Response : No Cycle Wait : No System Error Line : No Fast Back-to-Back : No Detects Parity Errors : No User Defined Format : No PCI 66Mhz Bus Support : No New Capability List : Yes PCI Support : Vendor-Dependant > Physical Memory : 2048 MB DDR2-SDRAM >> General Information DIMM_A ( ) : 1024 MB - DIMM DIMM_B ( ) : 1024 MB - DIMM >> Information SPD EEPROM (DIMM_A) Manufacturer : Kingston Part Number : Unspecified Serial Number : 68216419 Type : DDR2-SDRAM PC2-4300 (266 MHz) - [DDR2-533] Format : SO-DIMM (67,6 x 3) Size : 1024 MB (2 ranks, 4 banks) Module Buffered : No Module Registered : No Module SLi Ready (EPP) : No Width : 64-bit Error Correction Capability : No Refresh : Reduced (.5x)7.8 µs, Self Refresh Voltage : SSTL 1.8v Prefetch Buffer : 4-bit Manufacture : Week 11 of 2006 Supported Frequencies : 200 MHz, 266 MHz CAS Latency (tCL) : 3 clocks @200 MHz, 4 clocks @266 MHz RAS to CAS (tRCD) : 3 clocks @200 MHz, 4 clocks @266 MHz RAS Precharge (tRP) : 3 clocks @200 MHz, 4 clocks @266 MHz Cycle Time (tRAS) : 9 clocks @200 MHz, 12 clocks @266 MHz Min TRC : 12 clocks @200 MHz, 16 clocks @266 MHz >> Information SPD EEPROM Manufacturer : Kingston Part Number : Unspecified Serial Number : 68214319 Type : DDR2-SDRAM PC2-4300 (266 MHz) - [DDR2-533] Format : SO-DIMM (67,6 x 3) Size : 1024 MB (2 ranks, 4 banks) Module Buffered : No Module Registered : No Module SLi Ready (EPP) : No Width : 64-bit Error Correction Capability : No Refresh : Reduced (.5x)7.8 µs, Self Refresh Voltage : SSTL 1.8v Prefetch Buffer : 4-bit Manufacture : Week 11 of 2006 Supported Frequencies : 200 MHz, 266 MHz CAS Latency (tCL) : 3 clocks @200 MHz, 4 clocks @266 MHz RAS to CAS (tRCD) : 3 clocks @200 MHz, 4 clocks @266 MHz RAS Precharge (tRP) : 3 clocks @200 MHz, 4 clocks @266 MHz Cycle Time (tRAS) : 9 clocks @200 MHz, 12 clocks @266 MHz Min TRC : 12 clocks @200 MHz, 16 clocks @266 MHz >> Memory Controller Information Memory Controller : System Memory Location : Mainboard Error Correction Capability : No Number of connectors : 2 Max. Module Size : 4096 KB > LPC bus : Yes >> Bus Information Type : ISA - LPC Device : 82801FBM (ICH6M) LPC Interface Bridge Revision : 03 Number of ISA Connectors : 0 >> Device Capabilities (PCI) I/O Access : Yes Memory Access : Yes Bus Master Capable : Yes Special Cycle Recognition : No Memory Write & Invalidate : No VGA Palette Snoop : No Parity Error Response : No Cycle Wait : No System Error Line : Yes Fast Back-to-Back : No Detects Parity Errors : No User Defined Format : No PCI 66Mhz Bus Support : No New Capability List : No PCI Support : PCI-Express > PCI Bus : Yes >> General Information Number of PCI Bus : 2 Number of PCI Connectors : 0 >> Peripheral Type >> General Features Support PCI Mechanism 1 : Yes >> Bus Information #0 Device : 82915PM/GM/GMS, 82910GML Host Bridge Device : 82915GM/GMS, 82910GML Integrated Graphics Device Device : 82915GM/GMS,82910GML Mobile Express Family Graphics Controller (??) Device : 82801FB (ICH6) USB UHCI Controller 1 Device : 82801FB (ICH6) USB UHCI Controller 2 Device : 82801FB (ICH6) USB UHCI Controller 3 Device : 82801FB (ICH6) USB UHCI Controller 4 Device : 82801FB (ICH6) USB 2.0 EHCI Controller Device : 82801BAM/CAM/DBM (ICH2-M/3-M/4-M) Hub Interface to PCI Bridge Device : 82801FB (ICH6) AC'97 Audio Controller Device : 82801FB (ICH6) AC'97 Modem Controller Device : 82801FBM (ICH6M) LPC Interface Bridge Device : 82801FBM (ICH6M) SATA Controller Device : 82801FB (ICH6) SMBus Controller >> Bus Information #3 Device : BCM440x 100Base-TX Fast Ethernet Device : RL5c476 CardBus Controller Device : RL5c552 IEEE-1394 Controller Device : SD Bus Host Adapter Device : PRO/Wireless 2200BG Network Connection > AGP Bus : Yes >> Bus Information Number of AGP connectors : 1 > USB Bus : Yes >> Device Information Device : 82801FB (ICH6) USB UHCI Controller 1 Version : 1.0 Interface : UHCI Frequency : 48 MHz >> Device Information Device : 82801FB (ICH6) USB UHCI Controller 2 Version : 1.0 Interface : UHCI Frequency : 48 MHz >> Device Information Device : 82801FB (ICH6) USB UHCI Controller 3 Version : 1.0 Interface : UHCI Frequency : 48 MHz >> Device Information Device : 82801FB (ICH6) USB UHCI Controller 4 Version : 1.0 Interface : UHCI Frequency : 48 MHz >> Device Information Device : 82801FB (ICH6) USB 2.0 EHCI Controller Version : 2.0 Interface : EHCI > SMBus/i2c Bus : Yes >> General Information Device : 82801FB (ICH6) SMBus Controller Revision : 3 Frequency : 16 KHz Address : 0x10C0 >> Device Capabilities (PCI) I/O Access : Yes Memory Access : No Bus Master Capable : No Special Cycle Recognition : No Memory Write & Invalidate : No VGA Palette Snoop : No Parity Error Response : No Cycle Wait : No System Error Line : Yes Fast Back-to-Back : No Detects Parity Errors : No User Defined Format : No PCI 66Mhz Bus Support : No New Capability List : No > Bus HyperTransport : No > Bus CardBus : Yes >> Bus Information Device : RL5c476 CardBus Controller Speed : 33 MHz > Bus FireWire : Yes >> Bus Information Device : RL5c552 IEEE-1394 Controller ------------------------------------------------------------------------------------------ ***** End of report ***** |
Thanks for your reply...
I've tried also what you've written but the result was negative Spkguitar. I've uninstalled PT LE 7.4 and reinstalled 7.3.1 cs5. Ogun... |
Launch crashing at 'setting up midi' | paydoogs | Pro Tools SE and Essential (Win) | 1 | 10-21-2011 07:58 AM |
9.0.2 crashes when setting up MIDI peripherals? | tblythe.sound | macOS | 3 | 06-02-2011 09:38 AM |
Pro Tools Crashes setting up MIDI | products7074740 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-06-2009 07:11 AM |
MP 7.4 crashes during launch after "Setting up MIDI" | ajk | Pro Tools M-Powered (Win) | 29 | 12-14-2007 12:00 AM |
7.4 LE Still Crashes when SETTING UP MIDI! Where R U?? | Ogun04 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-25-2007 02:22 PM |
