Old 01-11-2009, 04:17 AM
danander11 danander11 is offline
Default Widening...
OK.. I'm relatively new to the recording side of all of this.. and one of the things I am curious to know how others use it, is stereo widening...
I downloaded Flux's free stereo plug in and love it..
I like to take the drums and bass and send to an Aux, as I do for reverb, etc.. and put the stereo plug on it, and flip the phase 90 degrees and then mix a little of it in to fill out the foundation of a song....
Ideas? suggestions? How do you use it?
Peace!
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Old 01-11-2009, 12:27 PM
Default Re: Widening...
Just my 2 cents but would not use it except as an effect. Any time you mess with the phase of something as important as drums and bass, you risk the quality of the final master. Go easy with the widener and always check your mix in mono before you let it out of the studio.
Old 01-11-2009, 02:50 PM
Cool.. exactly what I am looking for.. I would never have thought to listen to it in mono. Everything sounds great in stereo..
Being a noob stinks... being a noob at 50 is worse.. Better than being a slug I reckon.
Peace! (and thanks!)
Here I am,
Hobo Shave!
Old 01-12-2009, 10:24 AM
DrFord's Avatar
DrFord DrFord is offline
Noob = soon to be pro if he keeps learning.
Idiot = Noob who thinks he already knows everything (also called a teenager.)
DRFord
Homepage | Facebook | YouTube
Mac OSX 10.12.6 | Mac Pro 5,1 | 12core 3.46ghz
Avid HD Native PCIe Core | Pro Tools HD 2018.1
Old 01-13-2009, 06:43 AM
1ace1 1ace1 is offline
I suppose the best to use it is what sounds right to you works. Not very helpful I know. Sorry about that.
All it does is essentially delay and attenuate one channel by a small amount. It plays with our psycho-acoustic perception. As a sound arrives from the side must pass through the head to the other ear. The head is about the same width as a complete wave cycle at 1.6 kHz. so all frequencies below this are delayed slightly (to create a different phase relationship) whilst all frequencies above it are attenuated (as they would have completed one wave cycle). This gives the illusion that the sound is coming more from our side rather than striaght ahead. To much processing and the ears do not hear one sound arriving from the side but two sounds, one in each ear (due to to much delay). This can be to much and would sound wierd!! You can create your own with a sample delay and a basic filter.
Not sure how this helps you use it correctly though!
Just play and listen, when it sounds good, print it!
A:)
I Love Audio!!!
Old 01-13-2009, 08:53 AM
barismanco123 barismanco123 is offline
Look into the mid side effect - in some cases I have found it a great method when used on a stereo master to apply effects on or whatever seems right........
Old 01-13-2009, 09:59 AM
TCM's Avatar
TCM TCM is offline
M/S:
Try this http://www.brainworx-music.de/index.php?nav=26&um=2〈=en
002R BLA mod and Mbox mini 2, PT 11.3.2,
HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive
Old 01-13-2009, 10:05 AM
Stereo wideners work by taking a bit of each side, phase reversing it and feeding it to the other side, essentially creating a bigger hole in the middle. From what I have read, the best way for us budget studios to get wider sounding output is to use better converters. Every time I read about someone going from cheap converters(all the LE interfaces) to high-end converters(like Apogee, Lavry, Aurora) they always comment on how wider the stereo field is.
Old 01-13-2009, 03:56 PM
MUCHO! thanks to everyone.. Learning is cool.. especially from this side of things... (I've sat behind a drum kit for a long time).
Special thanks to Albee.. I would never have thought to check anything in mono... I did and found that in one thing I had done, when I went to mono, the guitar and vox cancelled each other out.. LOL (glad they're just my demos).
Now I listen to everything in mono from time to time and whenever I think I am finished just to be sure. I have to say that this little nugget has helped improve my mixes a fair bit.
Peace!
Here I am,
Hobo Shave!
Old 01-14-2009, 08:00 AM
DrFord's Avatar
Interesting tid bit here, alot of the big consoles and especially broadcast consoles will have a really crappy cheap mono speaker built into the console. This is again especially true for radio broadcast studios, as many older cars will only have one crummy speaker up in the dashboard. So the goal was to make sure you could have your track sound good even out of one speaker.
I know you are talking about a wider signal, but many times, it can be very important to make sure you have a good mono signal.
best of luck
D
DRFord
S1 Imager and 'widening' plugins...how do they work? aasteveo Pro Tools TDM Systems (Mac) 8 10-06-2012 07:51 AM
Mix window widening xes Pro Tools M-Powered (Win) 2 02-25-2007 12:17 AM
Widening Plugins Nicolasixxx Pro Tools TDM Systems (Mac) 7 05-22-2003 01:56 AM
Widening the Stereo Image Punx Tips & Tricks 12 01-16-2003 12:06 AM
Widening the Stereo Image? macjam Tips & Tricks 4 08-13-2002 10:52 AM
