Old 08-16-2019, 03:45 AM
groupeze groupeze is offline
Default Digidesigns Control24
I am using a Control 24 with protools using v control.
I had initial problems but v control sorted that.
I have a problem that the peak lights, all of them on the mixer section are on permanently as of yesterday.
And no signal is getting through the mixer section.
I am new to the C24.
Have I pressed something by accident or does the mixer section need to go in for repair?
I will be very grateful of some advice?
Also can anyone advise of a service centre in the South Wales area?
Regards
Groupeze
Old 08-16-2019, 05:19 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Digidesign Control24
Originally Posted by groupeze View Post
I am using a C24 with protools using v control.
Regards
Groupeze
Do you mean the original Digidesign focusrite Control 24 or the later C24
The issue sounds like a component problem hardware. first thing to check would be the power supply and its connections. remove and clean all connections and see if that helps. failing that then a repair centre..
Lee Engineering Ltd +44 (0)1524 846078 or +44 (0)1524 846070 Palatine House, Scotforth Road Lancaster LA1 4SA Email:
[email protected]
Website:
www.leeeng.co.uk
Chris
Producer, Engineer,
www.ukmastering.com
Old 08-16-2019, 05:37 AM
Thanks for your reply.
It is the control 24.
Can you point me in the direction of a service centre?
regards
Rhys
Old 08-16-2019, 06:09 AM
Southsidemusic's Avatar
regards
Rhys
He just did point you to a repair guy above ...
Which PT version are you using with that old thing?
If you have HD 10 you dont need the halfazzed Neyrinck application and if you have HD 11 and up you do need it but that Neyrinck is very restricted in functions compared to using the Control24 w/PT10 ...
Also remember that those units go for less than $1K in good working order, a friend here have one at a neighbour studio for sale at $700 mint condition so take that into consideration when you get a quote should you need to send it off for repairs.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 08-16-2019, 07:05 AM
TOM@METRO's Avatar
Default Re: Digidesigns Control24
Christopher is correct. Pouring money into one of these may prove to be disappointing in hindsight.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 08-16-2019, 07:59 AM
crizdee's Avatar
Ive had several repairs to mine over the years and its always been the power supply. last repair was about £100 but that was taking the PSU out of the desk and having it serviced/repaired.
I have a spare unit here with everything except the PSU as i keep that as a spare for mine. but unless you know the exact component that's failed i cant really supply you with anything
You can always try local repair centers and see if anyone is up for looking at it as it could and most likely is something simple.
Chris
Producer, Engineer,
www.ukmastering.com
digidesigns AS plugins joeydego Pro Tools M-Powered (Mac) 4 11-11-2008 11:32 PM
digidesigns hardware is in use problem! jakeelee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 11-26-2004 12:01 AM
Digidesigns support for Windows Holadrio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 05-17-2004 12:15 AM
My IRQ says I have 2 Digidesigns in 10 and 11. TriAxis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-09-2001 11:19 AM
What are Digidesigns plans for Surround Plug-Ins? Ah D O General Discussion 1 04-15-1999 01:39 PM
