Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 07-25-2018, 07:21 AM
rdpar's Avatar
rdpar rdpar is offline
Default drag and drop audio???
For some reason I can't drag and drop audio wav. files into pro tools project.
any suggestions??
Windows 10 Pro Tools 2018.3.1 Asus g752vt 17.3" laptop i7 Quad 2.6ghz 24gig ram
256ssd 1t hdd win. 10 Universal Audio x8P , Audient id22 interface. Focusrite Clarett Octopre
Old 07-25-2018, 08:12 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: drag and drop audio???
If you are using "Run As Administrator" for Pro Tools, you can't drag-and-drop.
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 07-25-2018, 09:55 AM
Benoni's Avatar
Benoni Benoni is offline
^^This^^
It use to be recommended to ALWAYS launch PT with Run As Admin. But since PT went 64 bit it's usually not necessary and in fact will cause this exact problem.
Drag and drop audio from Strike? Kinh Virtual Instruments 7 07-18-2014 05:33 AM
Audio import Drag and Drop bug? colinmansfield macOS 4 02-08-2012 06:08 AM
Importing Audio via Drag and Drop? derJ Pro Tools 9 13 12-12-2010 01:08 PM
Problem with Drag and Drop Audio milet22 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 06-17-2010 03:52 PM
drag and drop audio files peter99 Pro Tools TDM Systems (Mac) 2 02-04-2009 02:02 PM
