Old 11-17-2017, 11:48 AM
metalmixer metalmixer is offline
Default Commit track Delay Comp issue [BUG]
I have an open case with Avid support but I need this solved
First Commit tracks WITH OFFLINE works perfect
EXACT SAME SESSION EXACT SAME TRACKS
Commit tracks with ONLINE REALTIME - it does NOT Work Delay Compensation is ignored
I need to have online real time commit as I want to use hardware
see pics
Old 11-17-2017, 02:01 PM
Default Re: Commit track Delay Comp issue
A workaround: calculate the offset and SPOT or nudge the new audio(I agree this is not an elegant solution, but at least it works).
Old 11-18-2017, 05:26 PM
its a bug in pro tools - it's been there for quite a while FWIW it does not happen if there in 15 seconds of audio but for a 3 or 4 minute song it does not work.
Old 11-27-2017, 11:29 AM
Unfortunately the spot feature will not work the delay varies so it's never consistent
This really is an important bug too bad it got by the testers got it wrong and only tested it on 10 seconds of audio instead of 3 or 4 minutes.
This really needs to escalated.
Old 11-27-2017, 11:41 AM
Solution; don't hide the original track and use it to spot the committed version.
Old 12-09-2017, 01:48 PM
doing that to commit 40 - 60 hardware tracks is not a solution - Avid needs to fix this bug
Old 08-14-2019, 06:04 AM
Pyxis360 Pyxis360 is offline
Hello all
I'm on 2019.5 and Mojave, committing tracks with a hardware insert creates an audio track that is out of time.
If listening in realtime it's fine.
I've tried everything. An empty project with nothing but a single track and a hardware insert, tried turning compensation blue, etc. Nothing.
Has there been any update on this?
Thanks
Instrument Track Commit results in huge audio delay XJENSEN Pro Tools 12 23 01-13-2017 02:13 PM
12.5.1 and Delay Comp - possible AVE issue MIKEROPHONICS Post - Surround - Video 2 06-28-2016 04:30 AM
PT 11.3.2 Delay Comp issue quadraphonics Post - Surround - Video 7 02-25-2016 10:15 AM
Autotune Delay Comp issue bing181 AAX Plug-ins 2 09-03-2015 12:58 PM
Delay Comp On Aux Issue mattlange macOS 7 12-20-2010 09:19 AM
