Custom knobs mapping file location on a mac
In this video it's mentioned that "this also saves the map to your workstation so you can back the file up or even copy it over to another system" https://youtu.be/6v9mnPNUi6g Does anyone know where that file is located on a mac? |
Re: Custom knobs mapping file location on a mac
The custom Knob Map .xml files are located in -
~user / Library / Preferences / Avid / Consoles / "here" Note, it is not one file. It is an xml file for each custom mapped plugin. The export function in Eucon is for application soft key sets.
Matt McKenzie-Smith mattrixx.net SourceConnect - mattrixx AVID Collab user - mattrixx MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01 |
Thanks for the reply!
Unfortunately there's no such folder on my system, maybe it's a difference between the S1 and the S3? |
The User/Library folder is a hidden folder in the Mac OS. You will need to show hidden folders or press Command+Shift+period[.] while focused on the finder to show hidden folders.
https://osxdaily.com/2018/02/12/show...oard-shortcut/ |
Thanks again!
Still there's no console folder in the avid folder. Macintosh HD / User / Username / Library / Preferences / Avid / looks like this: Pro Tools (folder) Project Locations (folder) Space Packages (file) (Checked this one as well -> Macintosh HD / Library / Preferences / but there's no Avid folder there) Also did a finder search for "Console" but without any success. |
Have you created any plugin maps yet?
Thanks mattrixx, yes a couple and they all work when restarting Pro Tools
so they must be saved somewhere on the computer... |
If anyone else have the same problem I've made a workaround..
In the Avid folder, manually create a folder named Consoles with a subfolder named KnobMaps, now all your custom mappings xml files will end up there. |
What kind of account do you sign into the Mac with? I don't think anyone has seen this before and it could be a user permissions thing.
Thanks mattrixx! I'm setting up a new rig and I was stuck trying to figure out how to move my custom maps. All good now. 👍
Nathaniel Reichman Producer/Re-recording Mixer - New York Nathaniel Reichman | IMDB | LinkedIn |
Custom plugin mapping for knobs?? | stefanboman | Avid S4/S6 | 24 | 06-29-2021 06:56 AM |
Mapping MIDI CC's to Faders/Knobs? | KeyplayerG | Artist Series | 9 | 08-14-2018 10:42 AM |
Mapping of surround pan knobs on Mix/Control | espron | Artist Series | 0 | 01-03-2018 12:24 AM |
ProControl - Mapping Plugins on Knobs | Dario Ramaglia | ProControl, Control|24, Command|8 | 6 | 07-05-2014 03:05 PM |
Re-mapping AIR VI knobs | Gothboy | Virtual Instruments | 2 | 06-23-2009 06:54 AM |
