Old 12-01-2018, 11:36 PM
locationsound_at locationsound_at is offline
Default TotalMixFX and Eucon Artist Mix
Hello
I can't get my Avid Artist Mix to work with TotalMixFX on my laptop (PC). It works perfectly on my desktop DAW (PC). I did exactly the same on my laptop:
- Intalling latest versions of RME drivers and Eucon,
- go to the Eucon Control Panel and setting up Mackie Control for TotalMixFX for midi ports 1-4
- go to MIDI setting in RME TotalMix and setting MIDI connection In/Out to EuMidi1, nnable remote controller select "in use" number 1.
- enable midi control in TotalMix FX options.
I've noticed on little difference: when i open the tab "assign" in EuControl while TotalMix is open on my laptop the name of my workstation is NOT shown in the applicaton line: It shows: "application: TotalMixFX on "
On my Desktop DAW it shows: "application: TotalMixFX on DAW"
When i open Nuendo on my laptop the workstation name is shown in EuControl and my Artist Contoller works: "Application Nuendo 7 on Ultrabook"
Thanks, Martin
Fireface UFX2 latest Driver
Eucontrol 18.3.0.244
DAW and laptop both PC, Windows 10 Home
Realtek PCIe GBE Family Network Controller on laptop
Old 12-03-2018, 02:25 PM
EddieJones's Avatar
Default Re: TotalMixFX and Eucon Artist Mix
Can I ask you to uninstall (using the installer and uninstall everything option) Then put v3.7 on and try. After that update(don't uninstall 3.7) to 18.3 again. Let me know ?
3.7 download
Old 12-05-2018, 11:38 PM
Hello Eddie, thanks for your reply!
I did what you asked me, but it made no difference. EuControl still could not make a connection between my workstation and the application "TotalMixFX"
But then i tried something:
- I kiled TotalMix and the RME driver in system tray.
- deleted the Midi assignment in Eucon Contol Panel
- made a new assignment for MidiPort 1-4 to TotalMixFX (Mackie Protocol) in the Eucon Contol Panel
- resartet RME TotalMixFX
And then everything worked fine. But after a restart again no connection between workstation and totalmix...
so it seems to be a small problem somewhere in the midi assignment.
how can I fix this in a way that it also works after a restart?
Thanks in advance,
Martin
Can I change Eucon Layouts with an Artist Mix or Artist Transport? amathie Artist Series 10 09-21-2017 07:29 PM
Eucon sees my Artist Mix as an MC Mix TheDavidLim Artist Series 1 11-29-2016 09:42 PM
Bug for Artist Transport since EuCon 3 Voyageur Artist Series 5 08-04-2016 11:58 PM
Artist Mix/Eucon Problem digitalpapaya Artist Series 0 04-19-2016 12:44 AM
RME TotalMixFX maps only to unit 1 Raphie Artist Series 0 11-23-2014 06:59 AM
