Old 04-28-2019, 11:05 AM
belasoul belasoul is offline
Default Premiere Pro AAF to PT
I will receive an AAF from Premiere. Since the Location Sound Mixer did not generate a Mixdown to Edit Picture with, the Editor loaded all Audios into the Premiere and will export an AAF for me.
Do i see it right, that there is no chance for me at this point to work with the original source Audio from the shoot? Or is there still a way to get PT Ultimate's Field Recorder Workflow going from here?
MacOs 11.6.7, RME Fireface UC, PT Ultimate 2022.9
Mac Pro 6.1/12-core,64GB RAM, Aja t-tap
Béla Brandes | www.bbsounddesign.de
Old 04-28-2019, 11:17 AM
kelsey's Avatar
kelsey kelsey is offline
Default Re: Premiere Pro AAF to PT
If the editor worked with all the production audio, why do you need to resync to the recorder files? You will already have all the audio tracks in your session.
https://wanderingear.net
Old 04-28-2019, 11:20 AM
The main reason would be that i could work with the original File Names and metadata, since PP renames all the files to my experience.
Old 04-28-2019, 11:22 AM
kelsey's Avatar
That is an annoying "feature" of premier. Unfortunately since premier strips away much of the metadata I don't believe there is a way to make the field recorder workflow work. You would have to look into a reconform software like Ediload.
Old 04-28-2019, 11:47 AM
Ok, thanks! Does anyone know if the common workflow MC --> PT Ultimate, to apply field recorder workflow on edited mix track is possible with premiere at all (without using third party software)?
What workflow do you recommend when getting a project from premiere?
Old 04-28-2019, 01:07 PM
Cheesehead Cheesehead is offline
I've been in this situation several times with Premiere and FCP.
At least you have all the audio in the AAF from the Editor.
I agree with Kelsey, use what's there if you can and save yourself a world of pain and possible 3rd party software expense.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
Old 04-28-2019, 02:44 PM
henningaround henningaround is offline
If you could get EDLs of all audio track you could reconform with EdiLoad to the rushes.
Old 04-29-2019, 12:59 AM
Thanks, i'll check that. Also there is 14day full trial of Conformalizer i plan to try.
Old 04-29-2019, 03:56 AM
There is a very detailed video for EdiLoad. Search for "conform location wav files using EdiLoad" at YouTube.com :)
Old 04-29-2019, 04:16 AM
AFAIK Conformalizer, although great at what it does do, (re-conforming Pro Tools sessions to video re-cuts) wont conform location Wav files for you.
You'd need Ediload or perhaps Kraken, which has a thread about it a bit lower on this board.
HTML code is On
OMF/AAF from Premiere Mitch Griffin Post - Surround - Video 8 12-13-2013 09:00 AM
Help with Premiere Andy A Post - Surround - Video 3 11-10-2006 01:58 PM
Pro Tools and Premiere. the_dr38 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-24-2006 11:20 AM
5.3.1 conflict with Premiere veck 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-06-2003 06:03 AM
DC-30+, OS 9.2, Premiere 6.0, QT 5.x Lee Blaske Pro Tools TDM Systems (Mac) 7 08-17-2001 12:03 AM
