  #911
Old 08-02-2010, 10:53 PM
nst7 nst7 is offline
Default Re: Pro Tools LE to HD upgrade special: Open discussion
Thanks for the info. Even if I found an HD core card cheap, I'm starting to see where that money might be better put to other things. I'll be really thinking about what I want to do.
  #912
Old 08-03-2010, 01:07 AM
yamlan yamlan is offline
Originally Posted by Bob Olhsson View Post
It depends entirely on what you are trying to do. For a home studio where you are almost never recording more than two or three performers at the same time and not under heavy time constraints, HD is usually going to be overkill.
When you NEED HD is when you also need a full on studio with a console, 50 mikes in the locker and the meter is running at $100+ an hour.
I'm not sure why people get so hung up on bragging rights.
Obviously HD works for studios that feel they need it. The general feeling 'round here is that, regarding this thread, LE users don't need HD. How do I know this? We bought LE. We would, however, like to have what has been asked over and over on a forum that has smack down virtual fist fights about a better LE.
Reeeeeally want me to upgrade to HD? Make the entire package the price of an 003. Now that would be special.
  #913
Old 09-26-2010, 08:25 AM
akewldewd akewldewd is offline
Originally Posted by Keybeeetsss View Post
OK, let's say u hav a session with 22 stereo tracks; In LE, that'd be 22 tracks because it doesn't go by voice count; In HD, that'd be 44 voices; Now, u'd still have 52 voices left in HD, depending upon how u use RTAS; but, the use of RTAS on AUX as well as VI's takes away voices; so say u have 5 VI's open, good-bye 10voices (stereo)...
LE, 22 stereo is 22 tracks with 26 stereo tracks left regardless to how many VI's or aux, RTAS u use...
In my older protools le 6.1 with digi 001 a stereo track used two voices. If I ran out of room, I could convert a stereo track to mono and add another track. I just moved up to pt 8, perhaps it is different now?
  #914
Old 09-26-2010, 03:12 PM
The Weed's Avatar
The Weed The Weed is offline
Yes, there are no more voices in LE, just track count and you get 48 tracks mono or stereo. (If you search under User Name Shan there is a way to up the count to 96, but my memory isn't up to the task today.)
DV Toolkit 2 and Music Production Toolkit 2 up it to 64 tracks. The Complete Production Toolkit ups it to 128 tracks.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
  #915
Old 09-27-2010, 12:40 AM
nerhal nerhal is offline
hello. so I am interested in pro tools HD for a couple reasons and want to know the benefits it has to LE. I heard if you get the hd cards you can record with no latency and also it frees up your ram so it can be dedicated to cpu tasks and plug ins? also what is the difference to audio quality? I mean it is pro tools HD what is so HD about it compared to LE? I heard in LE it doesn't clip as easily as HD and that they are both built around different codes LE 32bit , HD 48bit? what is the difference there? I have heard plenty of LE sessions and a few HD systems and from what I can tell the HD usually ends up sounding clearer and with higher headroom. could that be because of what they were built off of as a program? I am curious before I go and spend the ridiculous investment into an HD rig?
I also want to know the difference between the different HD interfaces such as 192 I/O.
what I am looking for is to be able to record at least 16 tracks at once using a C|24 and an HD interface with pro tools HD with its cards at least an HD2. what would I all need. I don't want to talk to a guitar center rep they are idiots.
AMD Phenom(tm) II X4 955 Processor 3.21GHz
Gigabyte GA-790XTA-UD4
Total Memory : 4GB DIMM DDR3
Memory Bus Speed : 2x 670MHz (1.34GHz)
western digital black (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 932GB (C:)
western digital black (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 932GB (D:)
Memorex DVD+-RAM 550L v1 (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (G:)
Windows 7 Ultimate 6.01.7600 x64
gateway 24inch hdmi dvi HD monitor
pro tools LE 8.0.4
  #916
Old 09-27-2010, 09:42 AM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
The biggest limit on audio quality is the analog to digital conversion process. There are also some plug-ins that are only available for HD.
Bob's room 615 562-4346
Georgetown Masters 615 254-3233
Interview
Artists are the gatekeepers of truth! - Paul Robeson
  #917
Old 09-27-2010, 09:49 PM
u did not really answer my questions
pro tools LE 8.0.4
  #918
Old 09-27-2010, 10:18 PM
leester1172 leester1172 is offline
Native!!!!!!
  #919
Old 11-06-2010, 07:05 PM
100595 100595 is offline
Found this interesting in light of Pro Tools HD Native
But more interestingly Pro Tools 9 Crossgrade with 96 tracks and latency correction
Have any of you working natively off your CPU considered these options?
If so do they answer your prayers?
I myself am an LE user and considering an upgrade, but not there's no hardware restrictions and an ability to run up to 126GB of memory on my Win7 native seems desirable.
Native HD, perhaps?
I'm interested to know how native really runs in a professional setting because my LE system has choked many times before, I must admit.
  #920
Old 11-24-2010, 09:31 PM
TOM@METRO's Avatar
Desirable, but not reality.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2019.10 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Say what you want, but AVID allows great open-discussion & community kaiserpathos General Discussion 8 06-14-2011 05:49 PM
Open for discussion: freedom, openess provides profit and innovation TCM General Discussion 1 05-29-2010 04:08 PM
Pro Tools LE to HD upgrade special: Open discussion Tony Cariddi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 194 01-11-2010 11:04 PM
Open discussion: iLok. All welcome. RobMacki Pro Tools TDM Systems (Mac) 80 10-13-2004 09:51 PM
IK Upgrade Special Joe Evans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 04-11-2004 05:49 PM
