Legacy Control Surface Support - MP9?
I purchased an Avid/M-Audio C600 a few months back on closeout. Thus far, I am using it as a front end for Logic 9 (am I allowed to say that on this board? ) and it is working flawlessly. I also have a CM Labs MotorMix that I picked up from a user here that is connected via the C600's MIDI I/O.
I've been playing around with ProTools SE and thinking of switching to PT as my DAW. The MP 9.0.5 version works with the C600 and I can pick it up on the cheap as it's been EOL'd. The question is... MP9 shows support for Command|8 and Artist Mix, but no one mentions the old CM Labs stuff anymore (ProTools MP 9.0 Supported Devices). Has anyone used legacy ProTools controllers like the MotorMix to successfully control MP 9.0.x, or am I limited to the Command|8/Artist Mix? If it matters, I'm not so concerned about plugin control, editing, or transport control (I can do that from the C600). I'm mostly concerned with the fader bank of the MotorMix. Much thanks! |
Re: Legacy Control Surface Support - MP9?
Im pretty sure there is a way to download the legacy drivers to use with the motormix i know because i have done it on my yamaha 01v...
Try doing a google search onlegacy driver for protools it should give u the link to download it and itnstructions tu setup as well |
Thank you for the response. May I ask a clarifying question on your setup: Are you using your 01v to control PT MP? On Avid's FAQ's, there seems to be a different set of support guidelines for MP 9 vs. HD 9.
Much thanks. |
It is the same for both
Yamaha 01v can be set up to simulate cm labs controller Motormix is hui I think |
003 control surface (As audio) & control 24 as surface | crizdee | ProControl, Control|24, Command|8 | 7 | 01-04-2016 12:30 PM |
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control | lberrios1962 | Pro Tools 10 | 18 | 05-26-2012 12:51 AM |
No legacy support after pt 10 | MusoPro | Post - Surround - Video | 11 | 10-25-2011 04:37 AM |
Legacy Support pages GONE | milesofwire | Digidesign Hardware & Software | 5 | 03-03-2011 03:09 PM |
No control surface support in the download version????? | GeToChKn | Digidesign Hardware & Software | 4 | 11-05-2001 09:51 PM |
