#21
Re: Mbox 3 Pro and the 003 Controller.
Ok this is a mixing AD/DA setup. What would you suggest I do in a tracking scenario? I would want to track through the Mbox.
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7 |
#22
If you set up the Mbox for AD/DA mode, then it should be ready to go.
You can just create tracks in Protools and select Spidf as the input. On a mono track, select Spidf Left or Spdif Right. On a stereo track, select Spidf Left + Right. On your Mbox Pro, you should still be able to select Mic/Line/Instrument, etc., on inputs 1 and 2. If using a mic or instrument, adjust the gain just like normal. |
#23
21.5" Mid-2011 iMac i5 QUAD 2.5GHZ 4G RAM ML 10.8.5--Pro Tools 10.3.9--Avid Mbox Pro / 003R--ICY DOCK MB664UEA-1S FW400 With: 500GB Samsung HD502HJ |
#24
If you used my standalone method of having the mbox still connected to the comp, you can use preamps 3-4 of the mbox as well as 1-2 (just not its conversion). In the control panel go to the tab for outputs 3-4. Bring up the faders for hardware inputs 3-4. Go TRS out of the Mbox outputs 3-4 to either 003 inputs 5-6 or 7-8. Now you have 8 pres while tracking through your 003, two of which have the Mbox conversion. What about LLM? With this setup you can only use it with outputs 1-2 of the 003. I route all my tracks in my session to one master aux before the master fader. this way its easy to change the output of my tracks from spdif to analog 1-2 by only changing the output of the master aux and my recording tracks. you can also set the master aux to output through both the 003 outputs 1-2 and the spdif 1-2. Youre limited to using the 003's headphone outputs for tracking this way. Unless you take a cable from the 003 outputs 1-2(the ones separate from the monitor outputs) to the inputs 5-6 on the mbox(these are coax and 1/8" trs only) and hold down the speaker button until it flashes, to route inputs 5-6 to the mbox main outputs and headphones(if they are on the same stereo mix). If you absolutely HAVE to have just the 4 channels of Mbox conversion, save your control panel preset. in pro tools select the mbox as the interface, and setup a new preset in the control panel according to how you will be tracking.
Mackie Controller w/MBox 3 Pro | anackman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-26-2011 12:29 PM |
Midi Controller with MBox | jazzmandan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-12-2008 03:17 PM |
Mbox Keyboard controller? | sssaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-13-2007 12:20 AM |
USB midi controller with Mbox | ian_wize | Tips & Tricks | 2 | 12-16-2004 07:55 PM |
Midi Controller for Mbox? | H.R. Toad | Tips & Tricks | 3 | 10-30-2004 01:06 PM |
